Snapping modded h2e turbine shafts - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-22-2014, 04:14 PM Thread Starter
I've got rosewood stage two split shot injectors to start with. I bought a moded h2e(66/71/17) with t4 mounting used from an individual. When I first installed it I noticed something was off. The turbine shaft broke. So I bought a new shaft and rebuild kit and rebuilt the turbo. I reinstalled it and drove it for a couple days. Then it started doing the same thing a couple days back. It's broken two 300 dollar turbine shafts now. What's the problem? Im completely lost at this point. Before I buy another shaft does anybody have any ideas why it keeps happening? I know I'm going to have to get another shaft regardless. Thanks yal.
aikend is offline
post #2 of 10 (permalink) Old 07-22-2014, 06:39 PM
Wyo
scouts out...
Wyo's Avatar
Re: Snapping modded h2e turbine shafts
Do you have pictures of the failed turbine shafts?
2007 CC, Lariat, 6.0L, TreadWright guard dogs, straight piped out the back, egr delete, blue spring, 6.4 banjo bolts, high idle mod(bcp), bulletproofed, SCT Livewire TS with Drews street runner(under development for high elevation), Innovative, and Vivian's tunes, ww2.
Wyo is offline
post #3 of 10 (permalink) Old 07-22-2014, 08:48 PM Thread Starter
No. But the first one broke off right at the turbine wheel. The second one I'm not sure of yet because I havent torn into it.
aikend is offline
post #4 of 10 (permalink) Old 07-22-2014, 09:31 PM
Wyo
scouts out...
Wyo's Avatar
Part of my job where I work is to do root cause investigations on anything from jet turbines to recip turbos. If you can get me detailed pics I can probably tell if it's vibration, overload, or otherwise related.
Wyo is offline
post #5 of 10 (permalink) Old 07-23-2014, 01:08 AM
PsdPullerJR's Avatar
H2e is a pretty solid turbo that will take some abuse and I can't say I've read about anyone busting shafts. Have you been driving hard or just taking it easy?
2000 PSD Puller,6" stack, AFE Stage II, Auto Meter NVs, CPR-X Fuel system, H2E, Monster box, Stealth twins, 400/400 B codes, Minotaur software. 2000 F350 CC long box,xlt towing a 2011 Golden 20+5 GN.
PsdPullerJR is offline
post #6 of 10 (permalink) Old 07-23-2014, 01:15 AM
matthewd11's Avatar
after you replaced all of that you should have had it balanced IMO. Is it contacting the housing anywhere?
matthewd11 is offline
post #7 of 10 (permalink) Old 07-23-2014, 01:51 PM
2000 F350 SuperDuty 4x4
Calico5's Avatar
This is a turbo rebuild case where it's CRITICAL to have the rotating assembly balanced. Shaft, and both compressor and turbine wheel MUST be ballanced as an assembly.
It'll never last if you don't.
Al in SoCal
AFE Intake; Garrett 38R; Turbine Jacket; Banks IC, BanksBrake
Melling LPOP, External Oil Cooler & Filter System
Stealth 4-line Twin HPOP,
Swamps 160/30's, HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust, Twin Aussie Stacks
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
Calico5 is offline
post #8 of 10 (permalink) Old 07-24-2014, 03:19 AM Thread Starter
I really wasnt on it hard at all. But I'll get some pics up tomorrow.
aikend is offline
post #9 of 10 (permalink) Old 07-24-2014, 05:26 AM
Wyo
scouts out...
Wyo's Avatar
I'm willing to bet that's probably exactly what I will see, a fracture caused by high frequency vibration leading to failure. I'll keep an eye out for those pics.
Wyo is offline
post #10 of 10 (permalink) Old 07-24-2014, 04:10 PM Thread Starter
I cant figure out how to put the pics on here. Would you mind if I emailed them to you?
aikend is offline
