6637 install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-19-2014, 03:02 AM Thread Starter
6637 install
i installed a6637 filter on my truck and when I close the hood it hits the top of the filter is this normal or do I have to modify some thing else
longbowhntr is offline
post #2 of 8 (permalink) Old 07-19-2014, 03:16 AM
POWER Junkie
PSD POWER007's Avatar
Re: 6637 install
Loosen the the rubber flex pipe on both ends and turn that section till it's about an 1/8" from the boost tube and then tighten it back up. That will make the filter sit nice and flat.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #3 of 8 (permalink) Old 07-19-2014, 03:46 AM Thread Starter
Re: 6637 install
Thanks,it hits next to the fender the old airbox mounts on that side stick up alittle and wont let the filter sit down any farther.
post #4 of 8 (permalink) Old 07-19-2014, 02:27 PM
POWER Junkie
Re: 6637 install
I removed all of my old air box.
post #5 of 8 (permalink) Old 07-22-2014, 12:43 AM
Biscayne's Avatar
Re: 6637 install
I second the motion that ALL of the base of the old air box needs to be removed. I used a dremel tool with a cut off wheel to cut the portion of the base I didn't want.
_____________________________________________
2000 F350 CCSB 7.3 liter 4x4 mods- GP relay / PHP 6 pos / 6637 int / hutch / harpoon
2001 F250 ECSB 4x4 - sold
2001 F250 CCSB 2WD -sold
2002 F250 ECSB 4x4 lifted -sold
Mama's 2009 Expedition EL 4x4
Biscayne is offline
post #6 of 8 (permalink) Old 07-22-2014, 03:42 AM Thread Starter
Re: 6637 install
Thanks, I guess I will have to cut the bottom of the base off so it will sit a little lower ,I got it in there but when I close the hood it hits the top of it near the fender.Its a little louder than the stock filter especially when pushing it up a steep hill.
post #7 of 8 (permalink) Old 07-22-2014, 03:45 AM
POWER Junkie
Re: 6637 install
I used a table saw to cut mine, and I left the cold air tube so that cool air would get funneled up to the filter.
post #8 of 8 (permalink) Old 08-29-2014, 01:07 PM
Power Joke
TX_POWERSTROKE's Avatar
Re: 6637 install
yeah mine is like the same, looks like it sticks up but it still has a good inch or 2 when the hood is closed, I thought it would hit it or something but it turned out just fine..
2000 f250, 6637, No Limit tuning 6 pos. chip, autometer gauges, more on the way..
TX_POWERSTROKE is offline
