Good idea for homeade leveling or not? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-17-2014, 01:33 AM Thread Starter
USMCpowerstroke
Im just looking for a couple inches up front, the stock leaves are starting to invert. I don't like blocks so I wanted to do my own add a leaf, what about getting some x codes, then cutting up my stock springs and slapping those underneath the new leaves like a spring pack? Id probably have to drill a hole in a couple to use them in order to get at least 2.5-3 inches, then I figured id get a trac bar bracket then be set. Thoughts?
Okieboy32 is offline
post #2 of 4 (permalink) Old 07-17-2014, 05:36 AM
jtgf250's Avatar
Re: Good idea for homeade leveling or not?
Ummm, NO. If they are inverted, they are bad and need to be replaced. Blocks never go up front. Just get the X-codes and be done. They will actually give you about a 2inch lift over stock springs. If you need anymore then get as hanger kit. You'll need shocks and adjustable trac bar, or trac bar bracket. Also gonna need a set of u-bolts.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #3 of 4 (permalink) Old 07-21-2014, 12:26 AM Thread Starter
USMCpowerstroke
thanks for the reply, sure do appreciate it
post #4 of 4 (permalink) Old 07-28-2014, 04:02 PM
There can be only one
highlandre's Avatar
Wish I could afford my new springs. I'd sell you my Xs with the icon mini pack and/or my hanger kit.
2002 F250 CCSB 7.3L
AFE Stage 2, Muffler delete, Zone Offroad Nitros, dual SS,305/55/20 Trail Graps, SSBC brakes, TS Wildman, Autometer gauges, 6.5" Lift, '11 TG step/camera, Pioneer AV4400BTH, International Badges
highlandre is offline
