installed riffraff hpx line. driver side oil leak. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 07-11-2014, 04:05 AM Thread Starter
SD NEWB
Hey all I installed a riffraff hpx hard line this past weekend. The driver side is leaking oil pretty bad. Found a nice puddle underneath my truck. I torqued them correctly. So what gives bad o ring? Tried to snug it down but its not loose. It seems like its coming out the top.
03 Superduty 7.3 4x4 very much stock for now
84 m1009 6.2 4 inch lift on 33's {---sold it /tear
72 scout 345/727 stock
stoney126 is offline
post #2 of 7 (permalink) Old 07-11-2014, 10:37 AM
Re: installed riffraff hpx line. driver side oil leak.
Ditch it, because it us just another spot to leak oil.
02 f250
countryboyrob is offline
post #3 of 7 (permalink) Old 07-12-2014, 12:00 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
pull the check valve out of outlets on the pump..you get about the same results...
Ron's power stroke is offline
post #4 of 7 (permalink) Old 07-12-2014, 01:26 PM
POWER Junkie
PSD POWER007's Avatar
Once you torque the fitting into the head, you have to tighten the line onto the fitting until you get a good seal.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #5 of 7 (permalink) Old 07-15-2014, 04:14 AM
m j
m j's Avatar
oring would leak out the bottom, you didnt seat the JIC flare if its coming out the top
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
post #6 of 7 (permalink) Old 07-15-2014, 05:40 AM Thread Starter
SD NEWB
Pulled it off found grooves along the wall. Riffraff is going to swap it out for me.
post #7 of 7 (permalink) Old 07-16-2014, 10:03 PM
Theres no need for it....
02 f250
