Lope-like issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-10-2014, 12:18 AM Thread Starter
Lope-like issue
On my way to work this morning the truck lost most of it's power and struggled to even get up a small grade. Got to work and parked it. Started it back up before i left work and it ran almost like it was an old car idling with a big cam just "loping". checked ICP sesnsor and it was covered in oil as was the pigtail. Bought a new ICP sensor but the pigtail won't be here til tomorrow. sprayed out the pigtail with some brake cleaner and put a little dielectric grease on the new sensor. fired it up and still same thing. hooked up my OBD2 adapter and checked on torque. my PSI on hpop was 650ish at idle in park (600-700 rpm) and 2900 psi at 2500+ rpm in park. I drove my work truck home (got fixed today) so my personal truck is still sitting at the shop. didn't take it back out on the road. I plan to swap out the pigtail on the ICP sensor tomorrow evening. however what else should i look at or symptoms should i look for?
1999.5 F350, 4x4, auto trans, 160k miles, only mods are glowplug relay(western plow), 6637 and well that's about it. tranny rebuilt at 114k with a shift kit (before i owned the truck) Any help would be GREATLY appreciated!
99 F350 (99.5 motor E99 suspension)
Rebuilt tranny (with shift kit) @ 114,000
6637, Foil Delete, IC tubes Boots and clamps cleaned
kenmore is offline
post #2 of 11 (permalink) Old 07-10-2014, 04:39 PM
fueled by Colecovision
golfer's Avatar
Garage
Re: Lope-like issue
did the truck ever throw a CEL/SES light?
no tuner/programmer/'box'/chip etc on the PCM?
golfer is offline
post #3 of 11 (permalink) Old 07-11-2014, 12:11 AM Thread Starter
Re: Lope-like issue
SEL is on only when its it running. Doesn't store a code that I can pull with torque. No tuner
kenmore is offline
post #4 of 11 (permalink) Old 07-11-2014, 12:18 AM Thread Starter
Re: Lope-like issue
New pigtail installed. No change. Could the CPS do that?
kenmore is offline
post #5 of 11 (permalink) Old 07-11-2014, 01:55 AM
Re: Lope-like issue
check you valve cover gaskets mine did the same thing ran like #### cel was on no codes
obslove73 is offline
post #6 of 11 (permalink) Old 07-11-2014, 02:04 AM Thread Starter
Re: Lope-like issue
i will have to check that out then...good call
kenmore is offline
post #7 of 11 (permalink) Old 07-11-2014, 02:17 PM
golfer's Avatar
Garage
Re: Lope-like issue
constant SES/CEL can only be caused by:
A) lack of electrical continuity to 'an' injector (inj solenoid, inj wiring, IDM issue)< ie, something electrical
B) bad ICP sensor
if the truck doesn't have a dead misfire on one/more cyls...then it's most likely an ICP sensor/harness issue.
highly recommend using OEM Ford/Motorcraft sensors
golfer is offline
post #8 of 11 (permalink) Old 07-11-2014, 06:50 PM
Re: Lope-like issue
B) bad ICP sensor
Also, you have a constant SES light but no codes? That seems odd. As long as you have a scan tool that will pull Ford enhanced codes, you should be able to pull something from that light. Unless something fishy is going on with your PCM.
post #9 of 11 (permalink) Old 07-13-2014, 12:33 AM Thread Starter
Re: Lope-like issue
constant SES but when it gets turned off no codes and no SES
kenmore is offline
post #10 of 11 (permalink) Old 07-13-2014, 02:29 PM
Village Idiot
southmike's Avatar
Re: Lope-like issue
I had some funky idle with a ses ..was the uvch.
then had similar situation again, but that was fuel pump failing.
cant remember if that had a light or not.
southmike is offline
