Stock bottom end - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 07-07-2014, 01:05 AM Thread Starter
Willmister08's Avatar
Stock bottom end
How much hp will stock forged rods and the stock pistons handle only thing that would be changed would put a griddle in it.
Willmister08 is offline
post #2 of 20 (permalink) Old 07-07-2014, 01:16 AM
97250HD's Avatar
Re: Stock bottom end
"The Lone Stroke" put out 700+ IIRC on stock bottom end.
97 F250 eclb. 265k
- Fresh engine. d60. zf5. Some other stuff...
E99 f550 213k
- starts every morning...
97250HD is offline
post #3 of 20 (permalink) Old 07-07-2014, 02:13 AM Thread Starter
Sweet thinking about leaving bottom end stock and just getting heads done
post #4 of 20 (permalink) Old 07-07-2014, 03:35 AM
mikes95powerstroke's Avatar
Is putting a girdle in for a piece of mind or is it needed for say over 600 hp?
Black truck. 350/200 S472sxe arp, beehives, pushrods, fuel lab pump, stealth twins, swamps idm. Dana60 with ox locker. 33 row dorman transmission cooler. BTS transmission. 20x12 mo970 305/55 toyo open country.
2011 f350 36xxx 20x12ís -44 leveled.
White. 230,xxx 1995 f250 Dana 60, 5inch diamond eye. 6637. Winter/work truck.
mikes95powerstroke is offline
post #5 of 20 (permalink) Old 07-07-2014, 03:44 AM
whistle tits
ghohouston's Avatar
It's a good idea. I wouldn't go bigger than 250's on forged rods. 600 ish hp is about the range most have successfully pushed forged rods to. Some have luck with more power, and some have had bad luck with even less power.
ghohouston is offline
post #6 of 20 (permalink) Old 07-07-2014, 04:01 AM
Guess it's all a matter of luck.
post #7 of 20 (permalink) Old 07-07-2014, 04:17 AM
96powerstroker's Avatar
I'm pretty sure 600 is nothing & why get the heads done? The heads on a diesel don't matter usually
Sent from AutoGuide.com App
96 F250 2WD, 286K, Built E4OD, 180cc Injectors, Tony Wildman Tunes, Beans Fuel System, 3in DP - 4in MRBP exhaust, CAI, 4:10LS SCLB, Traction bars,
62 F250 4X4, 223 I6, T98 4 speed, 4:56s RCFS (Reg Cab Flare Side. Factory) 31x10.50x15s, currently on 16in Alcoas
96powerstroker is offline
post #8 of 20 (permalink) Old 07-07-2014, 04:43 AM
97250HD's Avatar
Heads do matter. Getting the air in and out quicker is the key of any engine to optimize power.
The deciding factor is at what point is it practical and beneficial. Along with what is done to the heads.
97 F250 eclb. 265k
E99 f550 213k
97250HD is offline
post #9 of 20 (permalink) Old 07-07-2014, 05:10 AM
the stryker god
This is just full of fail
bruce51d is offline
post #10 of 20 (permalink) Old 07-07-2014, 07:37 PM Thread Starter
I have 300/200 just wondering what everyone's opp on stock bottom end was.
