Cooling mist Problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 07-02-2014, 02:17 PM Thread Starter
hyrk's Avatar
Just installed the MPG stage 3 system and ive been having problems. Been getting both the hi current and low current alarms. Ive called cooling mist a couple times and during first call he told me to manually learn so i did that and still got alarms. Next call was to increase the parameter 8 & 9 numbers untill the alarm no longer comes in. I have maxed out these parameters at 50 and still getting alarms. Ive checked lines for plugging, pulled injectors out and ran them maually and seems to run fine into atmospheric pressure. Really ticked at this system so far as everytime i get an alarm the truck has to be shut to get it out of alarm mode and get my boost reading. (just installed a small switch to shut power for resetting) Also when it seems to be working my egts dont seem to change much. Ive heard of 200 F declines but im nowhere near that. Got #2 and #10 (at max output) injectors. Anyone with info is greatly appreciated.
2002 F-350, S&B intake, 38R tubro w/ wwII, EBV delete, CFM manifold, Spearco i/c, Adrenaline HPOP, Casserly stage I AC injectors , ITP Reg. return, DI Headers, hutch fuel mod, Cooling mist stg. 3, 4" MBRP Exhaust, transflow 46 and 40 gal fuel tanks/tool chest, Tunes by GAP, 4" pc lift, 22" Tis 534 wheels w/37"x 13.5" Dakar MT's, 4.30 gears
hyrk is offline
post #2 of 21 (permalink) Old 07-02-2014, 04:46 PM
the stryker god
Re: Cooling mist Problems
If you're having egt issues with ac's, a 38r a spearco ic then you have other problems. With a modded h2e and 250/200's I could tow pretty much as heavy as I wanted as fast as I wanted without problems
bruce51d is offline
post #3 of 21 (permalink) Old 07-02-2014, 05:46 PM Thread Starter
hyrk's Avatar
yep, thats my thoughts exactly...just had the family out with the holiday trailer and couldnt keep the egts under 1150 F with the cooloing mist. All boost boots are tight, clean filter, clean intercooler, Next step is a new thermocouple.
hyrk is offline
post #4 of 21 (permalink) Old 07-03-2014, 02:31 AM
OBSpstroke97's Avatar
Have you checked for boost leakes? Whos tunes are you running ?
1997 F-250, D60, 8in lift/38s, OUO ladder bars, BTS, Spearco 6.0 IC, SRP 1.1, Irate 468 turbo, Dyno proven tunes, P.I.S 300/200s, ARPs/910s/Smith bros push rods, A1000/sump.
[email protected] on 38s
OBSpstroke97 is offline
post #5 of 21 (permalink) Old 07-03-2014, 12:55 PM Thread Starter
hyrk's Avatar
No leaks that I can find. Still getting my 30psi with the 38r turbo. At the moment im using dp tunes. Gonna put matts (gap) tunes back in bf this big trip I have next week. I'm trying everything to keep this thing cool. (Engine and tranny are spot on, no problems there).. even went as far as removing my 4- 8" lights on Front bumper, thought maybe theyre blocking some air flow.
hyrk is offline
post #6 of 21 (permalink) Old 07-03-2014, 01:03 PM
the stryker god
id try another gauge
bruce51d is offline
post #7 of 21 (permalink) Old 07-03-2014, 01:38 PM Thread Starter
hyrk's Avatar
Yep. Gauge and thermocouple on its way. Talked with a guy yesterday, he said I should move from a 4" to a 5" exhaust... Not so sure that's an issue. . Thoughts?
hyrk is offline
post #8 of 21 (permalink) Old 07-03-2014, 04:59 PM
the stryker god
Down pipe size wouldn't change. With all that stuff you have egts should be a none issue.
bruce51d is offline
post #9 of 21 (permalink) Old 07-03-2014, 05:49 PM
5 inch exhaust is a waste to money stick with 4. they do nothing for performance and that pipe is hard to tuck under the truck
erstroke is offline
post #10 of 21 (permalink) Old 07-03-2014, 06:43 PM Thread Starter
hyrk's Avatar
thats what i figured thanks. ill post back after i get gauge in.
Kinda got sidetracked here...anyone have any experience with cooling mist? Still cant get alarms to go away for good.
hyrk is offline
