RR, Bowl Delete, Pump Serious Confusion... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 07-01-2014, 03:47 PM Thread Starter
ok I'm about to pull the trigger on a regulated return. Not a big deal, I'm also going to tackle the bowl delete, also not a big whoop. What is confusing the ____ out of me is the pump deal....I understand you have to have a post pump. If I am understanding correctly, this post pump IS NOT A FUEL SYSTEM (like the air dog and fass etc that goes on the frame rail). Is that correct? If that is correct, can I also put a fuel system on it. Is it compatible with the rr and bowl delete and post pump? Please help clear my mind, I tend to over think a little
g_nels is offline
post #2 of 15 (permalink) Old 07-01-2014, 04:43 PM
the stryker god
Re: RR, Bowl Delete, Pump Serious Confusion...
I think you mean post pump filter. Do the hutch mod, 25 micron pre pump filter/water separater, stock pump (2 in parallel if need be), 2 micron post pump filter, regulated return. Done
bruce51d is offline
post #3 of 15 (permalink) Old 07-01-2014, 05:11 PM Thread Starter
I'm just confused about what pumps I need. I totally understand rr and bowl delete, I just don't know what pump I need and why, I wanted to also get a fuel system such as airdog, I didn't know if this was the kind of pump they were referring too.
g_nels is offline
post #4 of 15 (permalink) Old 07-01-2014, 05:19 PM
the stryker god
Air dog and fass are junk. Stock Bosch pumps are great, reliable pumps. If you plan on making more than 500 or so horse you'll prolly need 2 of them.
bruce51d is offline
post #5 of 15 (permalink) Old 07-01-2014, 05:58 PM
LittleRedStroker's Avatar
don't make it harder than it has to be, we just did one where we disconnected at the quick connect, ran a hose to the filters mounted up by the battery/intake box, then to head. off the regulator for the return to the quick connect held on with hose clamps. very simple
superchip
wicked wheel
afe stage 2 intake
adrenaline hpop
mbrp 4 inch dual stacks
Originally Posted by sonic blue l View Post
if gm's were not so ugly i would be driving one...... actually thats just a joke. i would not be driving one even if they did not make babies cry.
LittleRedStroker is offline
post #6 of 15 (permalink) Old 07-01-2014, 07:11 PM Thread Starter
Yea I tend to make things harder than they are supposed to be. So last call,
I buy the rr.
I buy the bowl delete
I buy the post pump filter
That's it? I install all that and all is good right?
g_nels is offline
post #7 of 15 (permalink) Old 07-01-2014, 07:24 PM
the stryker god
What size injectors? A simple frx with hutch mod might do exactly what you need. Also you can run a RR with the fuel bowl
bruce51d is offline
post #8 of 15 (permalink) Old 07-01-2014, 08:14 PM Thread Starter
Still have stock injectors, that will be the next step.
g_nels is offline
post #9 of 15 (permalink) Old 07-02-2014, 06:59 AM
Terminator Nation
I buy the rr.
Like bruce51 says, you should also get a prepump filter (between the tank and pump).
old man dave is offline
post #10 of 15 (permalink) Old 07-02-2014, 09:21 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
you may want to build your own kit but you can get an idea what you need from this list
before pump
Driven Diesel Fuel Tank / Pre-Pump Kit
keep your stock pump in place until you decide on what injector you want..
after pump
Driven Diesel Post Pump Fuel Filter Kit
then use what ever regulated return you wish..
Ron's power stroke is offline
