Should I buy this truck? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-30-2014, 10:59 PM Thread Starter
I'm looking to buy a 2001 7.3L Powerstroke with 220K miles on it with the following add on's. It's a Black extended cab long bed. 10K
S&B Cold Air Intake
ITP Regulated Fuel Return
Garrett 38R Ball Bearing Turbo with 88m Inducer
TS6 Performance Chip
5inch Stack & 4inch turbo back
Airdog 100 Fuel Pump
John Wood Transmission
2500 Stall Convertor
Billet Internals
brand new 35" tires
Has brand new stock injectors cause one went bad and ford replaced them.
1. Is this a good setup up?
2. Would you suggest it need bigger injectors? If so, what kind?
3. What hp do you think it's pushing?
4. What questions should I ask the seller?
kobe123 is offline
post #2 of 6 (permalink) Old 06-30-2014, 11:08 PM Thread Starter
Re: Should I buy this truck?
Also, if i added bigger injectors what numbers would I see then?
kobe123 is offline
post #3 of 6 (permalink) Old 06-30-2014, 11:50 PM
the stryker god
Right now its makin prolly 325 horse. As for after injectors it would depend on the size of the new ones. I'd check to see if it has PMR before I decided to get too crazy with the HP.
bruce51d is offline
post #4 of 6 (permalink) Old 07-01-2014, 01:05 AM Thread Starter
Anyway I can do that without breaking open the engine?
kobe123 is offline
post #5 of 6 (permalink) Old 07-01-2014, 01:14 AM
the stryker god
Yep, pull the inspection plug by the oil filter housing. If you need visual assistance, Google it.
bruce51d is offline
post #6 of 6 (permalink) Old 07-03-2014, 05:20 PM
10k...jump on it.
2001 RCLB F250 4x4.
4" exhaust, php 6 pos. chip, gauges
wildjon is offline
