Boost gauge install? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 06-21-2014, 07:41 PM Thread Starter
7.3_KURT
Sanduner7.3's Avatar
what is the best place to read boost. which place is better and more accurate Is it the "T" fitting or the drill and tap. plan on getting gauges so obviously i what the mount them in the best spot.
Sanduner7.3 is offline
post #2 of 13 (permalink) Old 06-22-2014, 01:08 AM
m j
m j's Avatar
Re: Boost gauge install?
same accuracy
cant you do an IAH delete and use that opening as a plumbing spot?
I used this style plumbing to do mine with a bulkhead union at the firewall Pneumatic Fittings/Air Hose Fittings/Bulkhead Fittings/Union Fittings/Plastic Fittings
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
post #3 of 13 (permalink) Old 06-22-2014, 01:38 AM Thread Starter
7.3_KURT
Originally Posted by m j View Post
same accuracy
Will doing the delete throw a code and is it smog legal I live in cali
2000 7.3 zf6 4" AFE S&B intake SCT Programmer 6" procomp 37 BFG baja TAs .
post #4 of 13 (permalink) Old 06-27-2014, 07:16 PM
The delete will throw a soft code and you will likely not pass smog with it being deleted in Cali.
post #5 of 13 (permalink) Old 06-29-2014, 12:48 PM
Village Idiot
southmike's Avatar
My pmt pcm throws a code in the e99...
Not even sure there is a wire to attach one if I wanted too.
southmike is offline
post #6 of 13 (permalink) Old 07-04-2014, 10:12 PM
Terminator Nation
same accuracy
That site's info sheet rates the working temperatures for those fittings as 32* to 140* F or 0*- 60* C, seems low rated for the normal underhood temps of a PSD and not low enough for winter temps.
old man dave is offline
post #7 of 13 (permalink) Old 07-15-2014, 02:38 AM Thread Starter
7.3_KURT
i think im gonna do the t fitting.
post #8 of 13 (permalink) Old 07-15-2014, 02:39 AM Thread Starter
7.3_KURT
thanks for the help guys
post #9 of 13 (permalink) Old 07-15-2014, 02:57 AM
Village Idiot
southmike's Avatar
One good source for gauge installs I use is dieselmanor
they have great info and good prices on guages as well.
post #10 of 13 (permalink) Old 07-22-2014, 04:18 PM
did throw a code on my 01 excursion but got a wire that had a shunt or resistor or something like that, that draws enough current to trick the computer to think its still there. I don't remember where I got it, been a few years
96 F250 CCSB 4x4, D60, 3.55, Auto, 6.0 trans cooler 3"-4" down pipe & exhaust, not enough power
wildstang is offline
