What Goose-Hitch Friendly Air Bags???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-13-2014, 05:42 PM Thread Starter
nossliw's Avatar
Well I changed my mind to get away from the add-a-leaf for the rear and go ahead and buy a set of bags before I leave this next trip. Springs are nice and soft from the goose pounding away all spring, so I wanted to ask you all what you suggest. I do not need some crazy set of high end bags and it would be nice to push up 1000-1500 lbs of pin weight an inch or two to level it out. I went on to firestones website and they have the 2071 rear bags. I have no need for a compressor. I assume these will fit just fine, considering I have not measured for the 7.5Ē of clearance.
My dilemma is my Drop in lock Goose hitch wraps around the frame rail on the outside similar to a B&W. Who has a kit that works with a goose hitch? Do you have a part number? I really donít want to fab my own set since I have very limited time, but It would be very easy to do a cutout for the goose and simply weld a few beads to it, not the frameÖ However if Iím buying a kit Iíd rather not cut it up. Anybody who typically needs to run bags is probably more than likely have a goose hitch in the truck, and I couldnít imagine Firestone not making a kit that isnít goose friendlyÖ.
Anyways Iím asking you all what you suggest??? Come on I know there is a grip of you running them on hereÖ.
96 F250 CCSB, D60 SAS, 460, E40D, 3:55's, D-Thorleys
Sold the supercharged 547, 12V cummins twin swap in process
97 SCLB 7.3 PSD ZF5, 4:10'S, DP tuner, 6637, 4" Straight, EBPV delete, CCV delete, 3" plenums w 6.0 IC/ Rosewood stage 1's/waterinjection/ T500 ARPs, springs, rods and a 366 in process
nossliw is offline
post #2 of 4 (permalink) Old 06-14-2014, 02:21 PM
cltoney's Avatar
Re: What Goose-Hitch Friendly Air Bags????
I have the firestone kit and a b&w. Just get the kit that replaces the bump stops and mounts inboard of the leafs
cltoney is offline
post #3 of 4 (permalink) Old 06-26-2014, 06:40 PM
JJozwiak's Avatar
Link??
Blk 2003 7.3L 250 crew cab basically stock. Installed boost, pyro, and trans temp gauges, 6637 Air Filter and AIH to install boost line.
JJozwiak is offline
post #4 of 4 (permalink) Old 06-26-2014, 07:37 PM
slow learner
Jbolen323's Avatar
Send a message via MSN to Jbolen323 Send a message via Skype™ to Jbolen323
b&w is the only way to go for hauling.
2002 built forged7.3 350/200%| t4 w s468 | gearhead| BTS trans | 20* MB hpop| 6.4 conversion | 05 axle + 4link |PMF susp|
e1999 Tow pig 7.3 FF 160/100 | t4 w BASB Bell turbo | gearhead | adrenaline hpop| John woods Race trans|300k|
2003 ccsb stock 52k original owner.
Jbolen323 is offline
