Turbo failure.. What happened? (Pics) - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-11-2014, 08:44 AM Thread Starter
99psd7.3's Avatar
I had a weird humming/howl noise coming out of my exhaust for sometime had no clue to what the issue was... So after 2 months of checkin this an that I checked the shaft again an this time there was enough play that made me decide there's something going on inside so I pulled it apart and this is what I found...
Trucks a early 99
K&N FIPK cold air
Suggestions on what I should do an do you think I should to take it to a machine shop to be checked/balanced? Will just a rebuild kit get me back on the road?
Tell me what I should do and or what you would do.. I plan to rebuild it myself but if you guys think I shouldn't let me know..
Thanks Josh
Some scratches around the edge of the wheel.
No signs of the wheel hitting Compressor housing anywhere..
Huge gash wth.....
What on earth could of got between the wheel and backplate? All 4 bolts were damn tight..
Exhaust plate or whatever.. Oil was deffinately getting threw.. Wasn't enough to make the truck smoke at all..
All gunked up!! Damn.. Why tho?
Nasty.. It's like chunky dirty burnt oil, that hole isn't perfectly round anymore..
Deffinately signs of excessive heat on back side of compressor wheel and where all that gunk build up is.. The exhaust wheel itself looks fine nothing has hit it or has it rubbed anywhere..
Ideas on what I should do or what you would do in my situation? Anyone wants to see anything else let me know!
Early 1999 F250 eclb
Edge Juice w/Attitude, K&N Cold Air, 4in MBRP S.P, Foil Delete
17x9 Moto Metal 951's, 33" Nitto Terra Grappler A/T
Loudest 7.3 in Wa
99psd7.3 is offline
post #2 of 5 (permalink) Old 06-11-2014, 01:07 PM
Goneracin's Avatar
Send a message via AIM to Goneracin
Re: Turbo failure.. What happened? (Pics)
It looks to me like you need to clean it all up, get the burnt oil off, put in a rebuild kit, and a new billet wheel while you are in there.
2001 F-250 7.3L auto
Suspension stuff, engine stuff, reliability stuff...
Some other stuff I'm forgetting...
Goneracin is offline
post #3 of 5 (permalink) Old 06-11-2014, 03:46 PM
The "scratches" in the first photo are the results of the deburring process after the backing plate comes out of the diecast mold. Somebody breaks the sharp edge with some form of rotary tool.
The backside of the wheel, could use a better picture, but the "gash" at the 12 o'clock area ...from 10 to 2...is part of the process used to balance the wheel. It's been milled radially a bit. Looks like, again, a rotary scotchbrite wheel was used to buff an area.
'01 F250 4x4 Crew Shorty, PM Rods, PIS 160/30's , Hydra, WW2, Monster Box, MBRP 4" 409 SSTL Exhaust, Firestone Ride-Rights, Regulated fuel return, Ford AIS.
Dan V is offline
post #4 of 5 (permalink) Old 06-14-2014, 07:27 AM Thread Starter
99psd7.3's Avatar
Ok thanks for the info guys!
No one thinks I need to worry about taking the shaft to a machine shop to be ballanced once I get the new parts. I should be ok without having to?
Loudest 7.3 in Wa
99psd7.3 is offline
post #5 of 5 (permalink) Old 06-16-2014, 11:31 PM
Village Idiot
southmike's Avatar
There are two rings..aka seals that look to be missing on the shaft
thats what let oil by..if they were there they were prob worn.
i got a great kit from sp diesel off ebay.
the ww2 works on an e99 as well.
how are your uppipes holding up...i rebuilt mine while doing turbo.
ie replaced doughnuts.
southmike is offline
