putting new 7.3 in my truck and have?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 06-04-2014, 06:06 PM Thread Starter
norcalstrokin's Avatar
Hey everyone! I recently picked up a 2000 7.3 engine with 150xxx on it to swap into my truck. I am going to be changing some things before it goes in. So far im going to changing the
1. Water pump
2. Oil pan and seal
3. All the boots
4. engine mounts
5 up pipes
Is there anything else I should change while its out or parts that you guys would recommend to do while it's out? Thank you in advance!!!
2000 PSD 7.3 crew cab
6speed
6' skyjacker lift
k&n intake
edge evolution
banks waste-gate
banks Compressor Wheel
norcalstrokin is offline
post #2 of 20 (permalink) Old 06-04-2014, 06:11 PM
Re: putting new 7.3 in my truck and have??
I wouldn't change the pan unless it's leaking, or rusted out.there's no seal is just rtv
2000 F250 ccsb 4x4. 218,000 miles, 38r 1.0 housing with turbo master, 238/80% FFD hybrids, BTS
riff raff FRx, Autometer C2 series gauges, DIY tymar, remote start, Hydra with GEARHEAD Tunes
lariat7.3 is offline
post #3 of 20 (permalink) Old 06-04-2014, 10:22 PM
mikes95powerstroke's Avatar
Oil cooler o rings and gaskets along with oil rail plugs.
Black truck. 350/200 S472sxe arp, beehives, pushrods, fuel lab pump, stealth twins, swamps idm. Dana60 with ox locker. 33 row dorman transmission cooler. BTS transmission. 20x12 mo970 305/55 toyo open country.
2011 f350 36xxx 20x12ís -44 leveled.
White. 230,xxx 1995 f250 Dana 60, 5inch diamond eye. 6637. Winter/work truck.
mikes95powerstroke is offline
post #4 of 20 (permalink) Old 06-05-2014, 10:48 PM Thread Starter
thanks well do that. I'm debating if i want to do head gaskets before i put it in
[QUOTE=lariat7.3;4324706]I wouldn't change the pan unless it's leaking, or rusted out.there's no seal is just rtv
i do plan of changing the oil pan since i have one i bought for my other 7.3 but since i got this one. i was told might as well since its out
6speed
6' skyjacker lift
k&n intake
edge evolution
banks waste-gate
post #5 of 20 (permalink) Old 06-06-2014, 01:49 AM
OBSpstroke97's Avatar
[quote=norcalstrokin;4326954]thanks well do that. I'm debating if i want to do head gaskets before i put it in
Don't mess with the head gaskets unless you know for a fact they are leaking. 7.3 head gaskets rarely ever fail.
1997 F-250, D60, 8in lift/38s, OUO ladder bars, BTS, Spearco 6.0 IC, SRP 1.1, Irate 468 turbo, Dyno proven tunes, P.I.S 300/200s, ARPs/910s/Smith bros push rods, A1000/sump.
[email protected] on 38s
OBSpstroke97 is offline
post #6 of 20 (permalink) Old 06-06-2014, 05:45 AM
FuturePharmD's Avatar
X2 on the oil cooler gaskets. I just did mine at 200k and it's a pain in the a$$ to do in the truck. Also if the heads are not leaking don't mess with them!
2002 F250 ccsb Lariat 4x4
6637 intake
4" MBRP
Stage 1's by Full Force Diesel
Honey badger Jr hpop and Brute 66
Bellowed up-pipes and blank pedestal
No Limit Tuning by Jonathan (Dyno Proven)
Rough country level and shocks
305/70r16 Toyo AT2 on Dc2
Autometer factory match (pyro,boost,trans)
FuturePharmD is offline
post #7 of 20 (permalink) Old 06-06-2014, 07:49 AM
7.3-6.0-6.4's Avatar
X3 oil cooler maybe rearmain seal and front seal easier to do it now .
7.3-6.0-6.4 is offline
post #8 of 20 (permalink) Old 06-07-2014, 02:49 PM
Luddite in Charge
Mr_Andy's Avatar
Oil pan, rear main, and head gaskets hardly ever leak. If it ain't broke...
Gut the EBPV on the pedestal, or for $100 replace it with a non-EBP pedestal.
Oil cooler o-rings for sure - ignore all the other suggestions you've read except for the oil cooler o-rings!
Mr_Andy is offline
post #9 of 20 (permalink) Old 06-08-2014, 08:05 PM
Diesel Enthusiest
I have to disagree that the rear main seal hardly ever leaked that's is a spot known to leak on 7.3s. Change the rear main seal, the front seal, and do your oil pain and oil cooler deal. Another thing I would strongly consider is doing head studs while it's out because it's super easy to do. Just find the torque pattern online somewhere and simply unscrew one bolt at a time and then put the head stud in, just go one by one and it shouldn't take you any longer than a hour. I agree not to change the head gasket because that things had 150k miles of heat and crud sealing it up right now.
2003 F250 7.3 Lariat, 4 inch lift on 35 BFG AT's, 5 inch turbo back exhaust, afe cold air intake, TS chip, projector headlights, custom sub box, interior led's, underglow, 2% tint all 4 windows and rear, 30% window tint, color match bumpers and grille.
7_three_stroker is offline
post #10 of 20 (permalink) Old 06-08-2014, 08:39 PM
I'd still do oil rail plugs. The front two are cake with motor in as for the back two, have fun. Been there. They're like 20$ if that for the o rings, and 20$ for a piece of mind. Worth it in my book.
