duel stock fuel pumps - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-29-2014, 11:40 PM Thread Starter
Banned
can you put one before the other one or can you run them side
by side pushing thru same line.
sideswipe7 is offline
post #2 of 6 (permalink) Old 05-30-2014, 12:53 PM
the stryker god
Re: duel stock fuel pumps
parallel
bruce51d is offline
post #3 of 6 (permalink) Old 05-30-2014, 05:34 PM
mikes95powerstroke's Avatar
Will dual pumps be enough for any injector size? I've got two sitting on the bench and planning to run 250/200 when I get to the motor. Transmission first.
Black truck. 350/200 S472sxe arp, beehives, pushrods, fuel lab pump, stealth twins, swamps idm. Dana60 with ox locker. 33 row dorman transmission cooler. BTS transmission. 20x12 mo970 305/55 toyo open country.
2011 f350 36xxx 20x12ís -44 leveled.
White. 230,xxx 1995 f250 Dana 60, 5inch diamond eye. 6637. Winter/work truck.
mikes95powerstroke is offline
post #4 of 6 (permalink) Old 05-30-2014, 06:45 PM
the stryker god
Dual pumps are big enough for 250/200's easily
bruce51d is offline
post #5 of 6 (permalink) Old 05-30-2014, 09:55 PM Thread Starter
Banned
i got 2 pumps also and im running the 250/200 i can run single pump
but when i hammer it on the extreme mode fuel pressure drops 30lbs.
Just regular driving my single pump has no problem. When i have it
in the dd mode i can hammer it and not worry about it.
post #6 of 6 (permalink) Old 06-06-2014, 07:01 PM Thread Starter
Banned
can i run off of the the 2 wires going to the stock pump
to another pump or will that be to much of a draw on those
wires.
