1995 F-350 7.3 Questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-24-2014, 07:50 PM Thread Starter
Exclamation 1995 F-350 7.3 Questions
Hey guys, I'm a proud new diesel owner. Grew up my whole life fixing motorcycles and gas trucks. I am pretty handy under a hood. But my obsession has switched to diesels. I have been rodding out Harley's and chevy and ford gas motors for a while as a hobby. So now a new project:
-1995 single cab, long bed 7.3L Powerstroke with a 5 speed manual. All stock except Currently has:
-new trans
-state inspection ready (no leaks, dtc, etc)
-4" lift with 35x12.5x17 tires
-turbo back exhaust
-Dana 60s
What I want:
-any and all help for what performance parts to buy and install for about 2-3k price range that can mostly be done out of my garage. I have a basic diesel understanding i.e (glow plugs = spark plugs, inter cooler = radiator, injectors easier to upgrade, ICP = MAS)
-break it down Barney style, I'm thick skinned and ready to learn.
Thanks guys!
Wheelereod is offline
post #2 of 10 (permalink) Old 05-24-2014, 08:38 PM
jtgf250's Avatar
Re: 1995 F-350 7.3 Questions
Intercooler I guess you could consider a radiator for air lol. The single biggest thing you could do to wake it up right now as it sits is chip with tunes, I recommend a Hydra from PHP or Gearhead. Next would be to upgrade your HPOP, High Pressure Oil Pump. The 95 has a 15* style pump and going up to the 17* would help it. Even fairly stock engines see gains with upgraded oil pumps. Next, I would convert over to an electric fuel system with regulated return. No reason you couldn't do all that for around 2 grand. Good luck and keep us posted.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #3 of 10 (permalink) Old 05-24-2014, 08:53 PM
Vannnce's Avatar
I would recommend reading other peoples builds, perhaps figuring out what you wanna use the truck for and what kind of power youre trying to achieve. Your biggest friend here is reading and taking in as much as you can.
with that said, you already have an exhaust it sounds like? a good intake and a good set of tunes will really wake the truck up. I also would recommend a hydra. Your truck also does not have an intercooler, so that would be a good upgrade for you
2002 f350 Lariat 4" lift w/ 35's. DP tuned. Swamps 175/146 injectors. gauges. 5" turbo back exhaust
B&W turnover/ Companion 5'er
Vannnce is offline
post #4 of 10 (permalink) Old 05-25-2014, 08:11 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
you cant just put a 17* pump on a 95..you need to swap the front cover or buy a moded pump with the Anti-drainback feature
you should post your questions in the 94-97 forums..quite a few differences from OBS to SD..
1994-1997 OBS Power Stroke - Aftermarket Performance - PowerStrokeNation : Ford Powerstroke Diesel Forum
Ron's power stroke is offline
post #5 of 10 (permalink) Old 05-25-2014, 06:10 PM
jtgf250's Avatar
Sorry for not being specific on the pump, just stated to upgrade it. I guess some people would just swap them though since it was a 17*. I must have been thinking and not typed to check out Terminator Engineering, his T-500 would be a good upgraded pump.
jtgf250 is offline
post #6 of 10 (permalink) Old 05-25-2014, 07:33 PM
the stryker god
Glow plugs do not equal spark plugs and an intercooler does not equal the radiator and ICP sure as hell doesn't equal ICP. For that budget I'd start with efuel, intercooler and tranny mods
bruce51d is offline
post #7 of 10 (permalink) Old 05-25-2014, 08:17 PM
FNM
Iowa 73's Avatar
Gauges, injectors, and tunes are a good place to start.
Need to figure out your long-term plans for the truck before you decide on a set of injectors.
2013 Ram 3500 SRW, 4x4, 6.7L, 68RFE, 3.42's
1995 Ram 3500 DRW, 5.9L, 47RH, 4.10's
1997 F-250, 4x4, 7.3L, E4OD, 4.10's, 5.5" lift, D60, 37's, Baby Swamps, Swamps tunes, 1.0 housing and EBPV delete pedestal
1996 F-250, 4x4, 7.3L, ZF5, 4.10's
1992 F-350, 4x4 Dually Dump, 7.3L, E4OD, 4.10's
2003 SVT F-150 Lightning
Iowa 73 is offline
post #8 of 10 (permalink) Old 05-26-2014, 05:26 AM Thread Starter
Exclamation Re: 1995 F-350 7.3 Questions
Thanks guys! I've been doing research on everything you guys are putting out. Most common question is what I'll be using the truck for... I've been finding myself towing my racecar and restorations to competitions, which led me to a diesel, but also will use the truck as a daily driver. But as with any restoration, I also want to make it go fast. :) that's why I was leaning towards a gauge pod and a HUD programmer to be able to switch between settings to maximize my upgrades. But everything I've found is that a custom tune would be better than a chip of any sort. So that leads me to wonder if a turbo, injectors, hpop with a custom tune would be a good start. If you got anything used, let me know. Thanks for the help!
-Memorial Day! RIP.
U.s. Navy Special Operations
post #9 of 10 (permalink) Old 05-26-2014, 10:58 AM
jtgf250's Avatar
Custom tunes on a chip would be best hands down. Get some gauges and a Hydra chip. It will allow you to change tunes on the fly. Go to efuel before up sizing the injectors. As stated above, you need to set a hp goal and that will help you with what you need. Also as bruce said, the trans is a week point in these trucks when adding power so don't leave it out.
jtgf250 is offline
post #10 of 10 (permalink) Old 05-31-2014, 06:36 AM
Demon Dually
speeddemon31176's Avatar
It's a 5 speed manual. No tranny mods to be had other than putting a single mass flywheel with a better clutch.
speeddemon31176 is offline
