Injectors S366 will support - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 05-22-2014, 02:08 AM Thread Starter
Just trying to find out the biggest injectors I can go with on the new set up.
Build plan currently in progress:
-headers to t4 upipes
-1.10ar s366 with wicked wheel
-gearhead cam
-studs springs pushrods.
'99 F250 Super Duty (Mfd. Jan 99; Hybrid)
Stock 7.3, 4" straight pipe 5" tip, Isspro Gauges
K&N "cold air" intake
5" lift 35x12.50 TerraGrapplers
vtine523 is offline
post #2 of 18 (permalink) Old 05-22-2014, 02:12 AM Thread Starter
Re: Injectors S366 will support
-irate regulated return and fuel pump with sump
vtine523 is offline
post #3 of 18 (permalink) Old 05-22-2014, 03:44 AM
the stryker god
Is the 366 gonna be gated? If not a set of 230/100's if so then 250/200's
bruce51d is offline
post #4 of 18 (permalink) Old 05-22-2014, 07:47 PM Thread Starter
Yes. Hypermax45
vtine523 is offline
post #5 of 18 (permalink) Old 05-22-2014, 08:23 PM
the stryker god
Then 250/200, but that's on the high side. 200% nozzles are better suited for the s468. I think some 230/100's from Tim would be a good combo with that turbo
bruce51d is offline
post #6 of 18 (permalink) Old 05-22-2014, 11:57 PM Thread Starter
Typo earlier. Damn iPhone *turbosmart hyper gate. I like where your heads at Bruce and think I'm goingto have to go 468 and 250/200
vtine523 is offline
post #7 of 18 (permalink) Old 05-23-2014, 01:23 AM
the stryker god
If you go 468 then get some 300/200's from tim
bruce51d is offline
post #8 of 18 (permalink) Old 05-24-2014, 04:35 PM
06-6.0 stoker's Avatar
You better have some good up pipe upgrades and a lot of fuel pulled out of the tune if you plan on a 468 and 250/200s
Sent from AutoGuide.com App
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #9 of 18 (permalink) Old 05-24-2014, 07:47 PM
the stryker god
Wtf are you talkin about? 200% nozzles and a 468 are pretty much the most popular combo for a 7.3
bruce51d is offline
post #10 of 18 (permalink) Old 05-24-2014, 08:27 PM
jtgf250's Avatar
Bruce, how would a 468 and 238/200's do not gated? I don't want to buy a kit and then need a gate and have to rework everything.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
