Wicked Wheel 2 install, what else? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 05-19-2014, 09:38 PM Thread Starter
Hey guys,
I have developed an oil leak in the valley on 2000 F350 6spd truck. Truck has just a tad over 100k miles. I figure that while I am in there sealing stuff up I should go ahead and install wicked wheel 2. Ive got turbo surge I would like to clear up. So while I am ordering parts, what other preventative maintenance parts should I order from dieselsite while I am working in the valley?
So far my list is:
WW2 with turbo pedestal O-rings
Complete HPOP and IPR O-Ring Set 1994-2003 7.3L
High Pressure Oil Pump (HPOP) Repair Plug
Compressor outlet seal
Thanks
Stinson is offline
post #2 of 12 (permalink) Old 05-19-2014, 11:43 PM
Luddite in Charge
Mr_Andy's Avatar
Re: Wicked Wheel 2 install, what else?
For $108 get the non-ebp pedestal from them
Mr_Andy is offline
post #3 of 12 (permalink) Old 05-20-2014, 05:49 PM
richyrich's Avatar
Rebuild the turbo with a 360 rebuild so it won't have to be done down the road since you will be pulling it to do the pedi o rings also with a rebuild it comes with pedistal o rings and compressor housing o rings and turbo to pedistal o rings
2002
f-250 7.3L powerstroke superduty xlt sc sb 4x4 offroad, pure turbos 360 turbo rebuild kit,
mile marker 449 s/s hub locks, php phoenix 6 position chip, diy 6637 intake, 140k and rollin strong
richyrich is offline
post #4 of 12 (permalink) Old 05-22-2014, 12:58 AM
How hard is it to put the 360 bearings in a turbo?
95stroker45 is offline
post #5 of 12 (permalink) Old 05-22-2014, 05:05 AM
Village Idiot
southmike's Avatar
It was easier rrebuilding the turbo then it was to get it out or back in..two great videos on youtube.
And that ebpv rod can suck an egg.
southmike is offline
post #6 of 12 (permalink) Old 05-22-2014, 06:24 AM
richyrich's Avatar
Ebpv rod sucks
2002
post #7 of 12 (permalink) Old 05-23-2014, 01:33 PM
Goneracin's Avatar
Send a message via AIM to Goneracin
I second the rebuild. I did the 360 rebuild a little bit ago, very simple. RiffRaff diesel has a great writeup with pictures.
2001 F-250 7.3L auto
Suspension stuff, engine stuff, reliability stuff...
Some other stuff I'm forgetting...
Goneracin is offline
post #8 of 12 (permalink) Old 05-23-2014, 04:11 PM
I rebuilt the 01 excursion turbo with 360 bearing kit. I got it from barder turbo (I think that is the correct spelling), around
$98 or $89, anyways that was shipped and was like 2 days and I had it. Good price and service
96 F250 CCSB 4x4, D60, 3.55, Auto, 6.0 trans cooler 3"-4" down pipe & exhaust, not enough power
wildstang is offline
post #9 of 12 (permalink) Old 06-05-2014, 04:15 AM
What are the pros to the 360 kit compared to the stock? Im ordering delete pedestal/wheel as well and plan on rebuilding the turbo. Im also leaning on a 1.0 housing as well.
Thoughts on the bigger housing?
mkfan17 is offline
post #10 of 12 (permalink) Old 06-05-2014, 10:52 AM
SledDogg's Avatar
James Barder will sell you a 360 rebuild for $93. Ask for a used 1.0 non-wastegated exhaust housing for $150. You'll need a van flange (used ????$$$) or high flow outlet $100-150.
Call [email protected] DieselOrings .......he is awesome.
Fuel bowl rebuild $19-22
Fuel pressure regulator rebuild $ 62
CCV orings $6.40
Oil fill oring $1.60
Under valve cover hpop rail drain orings $5.40
Do .50 mod on wire plug. Google it.
Fuel line to cylinder head orings(may come in bowl kit)
I would leave your hpop alone. IPR orings maybe.
Remove AIH from spyder and install NPT plug.
While valve covers are off new MOTORCRAFT glow plugs $80-110.
Bob has Rancor (motorcraft) fuel filters for $18. Free shipping on orders over $100.
Dynoproven.com has bellowed up pipes for $250 & $400 ceramic coated inside and out. Check amazon also.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
