colt cam - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 45 (permalink) Old 05-13-2014, 01:47 PM Thread Starter
mech 1
colt cam
Has anyone used a coltcam in their 7.3 and did you notice a differnce in the so called fuel knock in the 1000 too 2000 range I did how ever notice when I tried the TS6 chip the higher i turned the knob the more of the knock went away
7.3mud is offline
post #2 of 45 (permalink) Old 05-13-2014, 02:02 PM
whistle tits
ghohouston's Avatar
Re: colt cam
I've never heard of anyone using a colt cam on a 7.3
ghohouston is offline
post #3 of 45 (permalink) Old 05-13-2014, 02:11 PM Thread Starter
mech 1
Re: colt cam
well I did and well just picking yalls brain I have a therory but want to see if anyone else thought the same thing
7.3mud is offline
post #4 of 45 (permalink) Old 05-13-2014, 08:38 PM
Re: colt cam
I would lean more towards your homemade injectors with the knock thing. Your gonna need custom tuning to get it to run right. Not just some off the shelf tuner or chip. Just sayin.
It's fuel and timing related. Nothing to do with camshaft.
swaan is offline
post #5 of 45 (permalink) Old 05-13-2014, 11:28 PM Thread Starter
mech 1
Re: colt cam
The injectors are working fine I'm pretty sure it's a timing thing see here's it when you buy performance cams their is a difference in lift duration and lobe separation and more so than not they grind advance into the cam so if their is advance or retard ground into the cam the injectors are quite possibly firing to soon or to late which would cause the fuel knock I'm here in hence why the chip made it better because it makes the injectors fire sooner or later just not sure which which is why I asked if anyone had run one. Runs to smooth for injectors to be the problem
7.3mud is offline
post #6 of 45 (permalink) Old 05-14-2014, 12:32 AM
m j
m j's Avatar
Re: colt cam
Colt is a couple miles from my girlfriends house, I am going to try one in my build
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
post #7 of 45 (permalink) Old 05-14-2014, 01:41 AM Thread Starter
mech 1
Re: colt cam
It defiantly makes a difference and is worth the money I just have to get the tunes right with my injectors and the colt stage two new build on motor factory hoop it will walk side ways out the hole going to take to watson racing have them custom tune it on a dyno I'll post the numbers when I do
7.3mud is offline
post #8 of 45 (permalink) Old 05-14-2014, 04:15 AM
the stryker god
Re: colt cam
The cam has nothin to do with timing in a 7.3. Timing is all based off tuning. Hopefully those people know what they're doin or the rods are gonna be hangin out the side
bruce51d is offline
post #9 of 45 (permalink) Old 05-14-2014, 04:22 AM
Re: colt cam
That's kinda what I tried telling him. It's not like a 3406 cat or big cam 400 cummins here. There is no injector lobe on the camshaft. Inj timing is all controlled by the ECM. Your cam is not your issue, your tuning is your issue.
swaan is offline
post #10 of 45 (permalink) Old 05-14-2014, 04:51 AM
Village Idiot
southmike's Avatar
Re: colt cam
I really wish i had the link for charles timming video.
southmike is offline
