7.3 parts for sale - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-03-2014, 08:23 PM Thread Starter
01 SmokeChoke's Avatar
Smile 7.3 parts for sale
Hi guys. I couldnt find a "sale" section but anyway I have a few things I need to get rid of.
up pipes with low miles and a good Y pipe collector flange (the one that goes behind the turbo) for a 99-03 gtp38 turbo. make offer.
USA ported housing. (no boot) When the turbo went the billet wheel made slight contact to it but it does not affect its performance, just put a couple light scribe lines in it. This was a large up grade for the stock turbo. this with the stock wheel made good reliable boost with ZERO surge. Much better than just a 6/6 wicked wheel. Sounds better too.. Make offer.
Rebuildable turbo gtp38. I have the stock wheel, stock compressor housing, the USA ported housing and a riffraff 12 blade billet wheel for ported housings. I can sell just the turbo with the stock housing, or all of it. Make me a offer. shipping this will be a factor in the price.
Transmission Range Sensor, replaced mine when I was trying to fix a issue that ended up being a faulty IPR connector, sensor is still good. Make offer.
IPR used, still good- again- changed when throwing parts at my truck when it ended up being a faulty connector. Make offer.
TS chip burner and software. Used 4 times. Make offer.
1 gallon water meth plastic tank. make offer.
IH Crate Engine,Cold Air,4" MBRP,6.5" lift,37" toyos,mx6 resis,Water meth,Stage 1s,Turbo Master,38R,6.0 CAC,6.0 trans cooler,FRx, Intank Mods,pre pump filter,AIH&EBPV deletes,Zoodad,456 yukon gears,Ladder bars,built trans,Aeroforce interceptor,quad pillar,PHP HYDRA,IH up pipes,Forged Rods
01 SmokeChoke is offline
post #2 of 2 (permalink) Old 05-04-2014, 04:16 AM
m j
m j's Avatar
Re: 7.3 parts for sale
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
