dana 50 longevity - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 05-02-2014, 09:04 PM Thread Starter
cpdad93's Avatar
dana 50 longevity
I have a miserably failing TTB that has never been right since I squished the mitsubishi eclipse into the pavement. I wanted to swap it with a D60 but happened across a D50 out of an SD real cheap. came complete with all steering and leafs. For an everyday driver and a stock 7.3, I am thinking this will be fine for me...after all the TTb is 15 years old. Is there some success with the 50s?
cpdad93 is offline
post #2 of 4 (permalink) Old 05-03-2014, 01:59 AM
rock blower upper
Re: dana 50 longevity
only difference in a sd 50 to 60 is the ring and pinion gear size and the bearing size , also the axle shafts are smaller at the carrier end .tube size etc wheel bearings, brakes , knuckles, steering, is all the same
03 7.3 sc 8' xlt, 4r100 4x4 was 03 2wd xl work truck, built what I couldnt buy
13 6.7 cc 8' 4x4
double-s-diesel is offline
post #3 of 4 (permalink) Old 05-03-2014, 07:21 AM
JSchuricht's Avatar
Should be fine for you. The only issues I foresee are the normal ones for a axle swap; gear ratio, lug pattern and spring perch position. Just read up on D60 swaps from a SD and everything should apply to the D50.
JSchuricht is offline
post #4 of 4 (permalink) Old 05-03-2014, 12:44 PM Thread Starter
cpdad93's Avatar
I needed new wheels anyway, got the front and rear axles along with all the steering and the leaf springs. It is missing the hubs so I will need hubs unless mine fit, and the rsk I guess.
cpdad93 is offline
