600 hp builld - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 32 (permalink) Old 04-30-2014, 02:21 AM Thread Starter
Willmister08's Avatar
600 hp builld
so im starting another build my goal is 600hp so any help would be appreciated so here is what I already have borg warner s468, 300/200 full force injectors full comp fuel system with regulated return spr 1.1 hpop mahle pistons forged rods 910 comp springs apr head studs and a built trans let me know what else I need. thanks
Willmister08 is offline
post #2 of 32 (permalink) Old 04-30-2014, 02:32 AM
jtgf250's Avatar
Re: 600 hp builld
May want to opt for Billet rods over forged at that power. Yes, I know people say they have seen motors make 600 with forged but its really pushing it.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #3 of 32 (permalink) Old 04-30-2014, 02:35 AM Thread Starter
Re: 600 hp builld
what about fordged cyro treated
post #4 of 32 (permalink) Old 04-30-2014, 02:36 AM
jtgf250's Avatar
Re: 600 hp builld
Maybe. Unless you get the ones from Hypertech
jtgf250 is offline
post #5 of 32 (permalink) Old 04-30-2014, 10:45 AM
the stryker god
Re: 600 hp builld
That'll get you close. I wouldn't waste the time or money on cryo forged rods but I would definitely put money back for some billet rods
bruce51d is offline
post #6 of 32 (permalink) Old 04-30-2014, 03:56 PM
Country's Avatar
Re: 600 hp builld
Subscribed
Carlos Briceno
99.5 CC F-250 4X4 with Full engine Rebuild.
02 Excursion 4X4
03 SC F-250 4X4
Oo..//.-----' --- '---. //////
OOo;.'-(o)------(o)-' ///
Country ><> Amen
Country is offline
post #7 of 32 (permalink) Old 04-30-2014, 08:38 PM
Re: 600 hp builld
I would ditch the srp 1.1 and go with Honey badger sr. and don't waste the 85$ on 910's call dynoproven and ask about there new crower valve spring kits. throw in a cam if you are going this far also from dynoproven
02strokers is offline
post #8 of 32 (permalink) Old 04-30-2014, 09:55 PM Thread Starter
Re: 600 hp builld
I was putting a cam in from gearhead but dyno proven have good cams?
post #9 of 32 (permalink) Old 04-30-2014, 11:35 PM
Country's Avatar
Re: 600 hp builld
I have a question. You said you already have Mahle piston that are going into this engine.
1.Which ones did you get?
Remember Block decking will require a certain piston height. Did you anticipate for this?
No being sarcastic, just checking to make sure you got the right ones.
And make sure your engine builder know this, and that he double checks on Moc up and after.
Carlos Briceno
02 Excursion 4X4
03 SC F-250 4X4
Country ><> Amen
Country is offline
post #10 of 32 (permalink) Old 04-30-2014, 11:48 PM Thread Starter
Re: 600 hp builld
I already have the bottom end built with them I messed up my heads and had to get heads but honestly thinking about tearing down the motor and starting over
