transmission getting hot - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 04-23-2014, 05:56 PM Thread Starter
2002 Powerstroke 7.3 diesel, the transmission seems to be getting warm whenever you pull something. Any ideas? Just changed all the fluids and filter and did a flush.
snort121 is offline
post #2 of 18 (permalink) Old 04-23-2014, 06:12 PM
Chachi
7.3PowerStroke602's Avatar
Re: transmission getting hot
do you have the stock trans cooler on your truck, if so id recommend putting a 6.0L trans cooler on there makes a big difference when towing lower temps=transmission longevity. also are you monitoring your trans temp off of your gauge in ur cluster or on a separate gauge. normal operating temperature of transmission fluid is about 100 degrees over ambient temperature
also how much are you towing?
2003 F350 7.3 Turbo Diesel
Rancho 9000 Shocks
4 inch exhaust into Soflo diesel 7 inch Mitre Stack
AFE Stage 2 Cold Air Intake
Glowshift Gauges-Fuel Pressure,Boost,Exhaust Temp. Aeroforce Interceptor Gauge on the Column
Swamps TS 6 Position Chip
Leveled Height with 35 Nitto Mud Grapplers
Swamps Diesel Boost Fooler
7.3PowerStroke602 is offline
post #3 of 18 (permalink) Old 04-23-2014, 06:19 PM
Bobs 7.3
Bobs 7.3's Avatar
what type fluid did you use?
Bobs 7.3 is offline
post #4 of 18 (permalink) Old 04-23-2014, 06:21 PM Thread Starter
i have a gauge pod i monitor off of. Pull a 32' excel camper with 20' Lund boat behind that
snort121 is offline
post #5 of 18 (permalink) Old 04-23-2014, 06:24 PM Thread Starter
Valvoline fluid
snort121 is offline
post #6 of 18 (permalink) Old 04-23-2014, 07:51 PM
the stryker god
What's the temp?
bruce51d is offline
post #7 of 18 (permalink) Old 04-24-2014, 03:25 AM
POWER Junkie
PSD POWER007's Avatar
6.0 cooler is a must when towing often.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #8 of 18 (permalink) Old 04-24-2014, 11:47 AM
Bobs 7.3
Bobs 7.3's Avatar
should have went with shaeffers all trans or mobil 1 syn as they are pricey it pays off in the long run.
Bobs 7.3 is offline
post #9 of 18 (permalink) Old 04-24-2014, 01:51 PM Thread Starter
it will get up to 220 at times, then i have to stop and just let it cool down
snort121 is offline
post #10 of 18 (permalink) Old 04-24-2014, 02:02 PM
Caption This
444-4D's Avatar
Under what driving conditions does it get to 220?
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
