Holy chip, I got boost - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-20-2014, 11:58 PM Thread Starter
Put my new f5 chip and some gauges on this weekend, I'm showing 35psi boost at wot. Soon after I get the ses, get off throttle and couple mins later ses is gone. I'm guessing waste gate is not working. What is the max boost I should run safely. Also 19 mpg before chip now my computer says I'm getting 33 mpg. Ya right!
Also what are max pyro and trans temps?
E99 F 250 4x4 Lariat
Buckeye Wes is offline
post #2 of 6 (permalink) Old 04-21-2014, 01:04 AM
Re: Holy chip, I got boost
Boost above 24 psi will set ses light on. A good tuner can fool the map. Also some tunes change the lie o meter drastically. You need to hand calculate. Stock turbo is stressed above 30 psi.
hoschtonhauler is offline
post #3 of 6 (permalink) Old 04-21-2014, 02:10 AM Thread Starter
Is the waste gate suppose to open at some point to stop from building higher boosts or do you just monitor it yourself?
post #4 of 6 (permalink) Old 04-21-2014, 02:55 AM
whistle tits
ghohouston's Avatar
Yes it just depends how far the wastegate rod is adjusted
ghohouston is offline
post #5 of 6 (permalink) Old 04-21-2014, 03:20 PM
SeeYa's Avatar
Have you checked for codes? Overboost has 2 codes. One for the sensor and one for voltage. Jody does set the values higher for the sensor code so the truck will not de-fuel. He does not adjust for the voltage code. Best guess you are setting the voltage code. You can install a overboost kit to prevent the voltage code. This will prevent the ses light from coming on when this boost code is set.
SeeYa is offline
post #6 of 6 (permalink) Old 04-21-2014, 06:35 PM Thread Starter
I don't have the capability to check for codes yet. I'm eyeballing the AE
