QSSB turbo questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-18-2014, 09:46 AM Thread Starter
Does anyone sell this turbo anymore? Does it use the t4 or t4i mount. After doing a fair amount of research it looks like this is the perfect turbo for me. Thinking about eventually going with 160/30 or 175/80 for a fun daily driver that can haul a largish 5er to the mountains. Heard this turbo lights like a 38r but has lower drive pressures thus making it great for long heavy pulls through steep grades. Plus, its rebuildable. Any info I can get would be great. Thanks!
Ja_cain is offline
post #2 of 11 (permalink) Old 04-18-2014, 12:21 PM
POWER Junkie
PSD POWER007's Avatar
Re: QSSB turbo questions
FYI, the billet wheels reduce drive pressures on the 38r to damn near a 1:1 ratio. My drive pressure is about 44psi at 38 psi of boost.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #3 of 11 (permalink) Old 04-18-2014, 12:45 PM Thread Starter
Your not helping. I have pretty much talked myself out of a drop in. Never the less, good info about the billet wheel/38r combo. I will still keep that in mind. Thanks!
Ja_cain is offline
post #4 of 11 (permalink) Old 04-18-2014, 01:16 PM
POWER Junkie
, just wanted to help you cover all angles.
post #5 of 11 (permalink) Old 04-18-2014, 04:03 PM
the stryker god
I got a modded h2e set up for sale.
bruce51d is offline
post #6 of 11 (permalink) Old 04-18-2014, 05:46 PM
QSSB is a great turbo and a good choice for your wants/needs. BTW, it is a T4i style mount.
post #7 of 11 (permalink) Old 04-18-2014, 09:20 PM Thread Starter
I was seriously thinking about yours but after doing some research I am not sure it is the right turbo for me. I don't know if I will ever run hybrids and read that it is a little laggy with smaller injectors (correct me if I'm wrong). If I was planning on eventually running hybrids then I would probably make you an offer. I like the idea of a QSSB since unmoded it falls in between an H2E and a modded H2E and can be further modded to a GQSSB if needed. Plus it will spool like a 38r with AC codes and has the low drive pressure of a modded H2E (or close to it). The other thing is I have a PMR motor and not sure when I will secure a good lowish milage forged rod block. I have a stick so a turbo that lights a little easier/sooner makes for a more enjoyable experience.
Ja_cain is offline
post #8 of 11 (permalink) Old 04-18-2014, 09:21 PM Thread Starter
I thought it was a T4i but wasn't completely sure. Thanks!
Ja_cain is offline
post #9 of 11 (permalink) Old 04-18-2014, 09:25 PM Thread Starter
Bruce,
Would you be willing to just sell the mount you have available? If yes, how much would you want? Thanks!
Ja_cain is offline
post #10 of 11 (permalink) Old 04-18-2014, 09:41 PM Thread Starter
Does anyone know how a HFSB would compare to a QSSB on spool up with 160/30 or 175/80's?
Ja_cain is offline
