What boost should I have with 230/100 injectors? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 04-16-2014, 11:42 PM Thread Starter
International Diesel Tech
purplepstroke's Avatar
I just installed 230/100s and a 38r billet wheel turbo. Right now the boost sits around 40 to 44 in the high rpms.. I was thinking about setting the wastegate so the boost is around 38. Getting it live tuned at dynoproven next wednesday so i want everything set right. What do you guys think? Thanks.
E99 7.3***230/100 PIS sticks***swamps tuning*** 4" mbrp***t500 HPOP***6637 filter***BTS valve body***racerx torque convertor***di reg return***walbro fuel pump***20x10 fuel hostages with Nitto 305 terra grapplers
purplepstroke is offline
post #2 of 18 (permalink) Old 04-16-2014, 11:57 PM
the stryker god
Re: What boost should I have with 230/100 injectors?
Sounds good to me. What happened to the 6.4 turbos
bruce51d is offline
post #3 of 18 (permalink) Old 04-17-2014, 12:11 AM
whistle tits
ghohouston's Avatar
That's a lot of boost for a 38r. Granted I pushed mine just as hard, iirc, much over about 30 psi, 38r's aren't doing much but blowing hot air. And I too would like to know what happened with the 6.4 turbos
ghohouston is offline
post #4 of 18 (permalink) Old 04-17-2014, 12:12 AM
whistle tits
ghohouston's Avatar
But as far as boost goes, that sounds normal for those injectors
post #5 of 18 (permalink) Old 04-17-2014, 01:17 AM
POWER Junkie
PSD POWER007's Avatar
40psi is the top edge of the 38r's range. What's your back pressure readings and EGT's at 40-44 psi of boost?
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #6 of 18 (permalink) Old 04-17-2014, 01:26 AM
whistle tits
ghohouston's Avatar
I got rid of that truck over a year ago. Didnt have a way to measure backpressure, but im sure it was high, egt's could get pretty damn hot if I stood on it, 16-1700ish iirc
post #7 of 18 (permalink) Old 04-17-2014, 01:28 AM
whistle tits
ghohouston's Avatar
Where did that figure come from?
post #8 of 18 (permalink) Old 04-17-2014, 01:36 AM
96powerstroker's Avatar
Wait 6.4 turbos on what? Fill me in on this?
96 F250 2WD, 286K, Built E4OD, 180cc Injectors, Tony Wildman Tunes, Beans Fuel System, 3in DP - 4in MRBP exhaust, CAI, 4:10LS SCLB, Traction bars,
62 F250 4X4, 223 I6, T98 4 speed, 4:56s RCFS (Reg Cab Flare Side. Factory) 31x10.50x15s, currently on 16in Alcoas
96powerstroker is offline
post #9 of 18 (permalink) Old 04-17-2014, 02:41 AM
POWER Junkie
30 psi tests the limits of the stock gtp38, not the 38r.
post #10 of 18 (permalink) Old 04-17-2014, 05:13 AM Thread Starter
It was only around 38psi boost until i put the beans billet wheel in. Backpressure is hard measure because the gauge keeps bouncing around. but id say its around 55psi.
The 6.4 turbos just had to much back pressure to boost for the 7.3 to handle. Apparently 6.4s can 70 psi of back pressure a lot better then a 7.4. I even put a 72mmm low pressure turbo in but did not do a thing for back pressure. I think the turbine on the high turbo is way too small for a 7.3. They could probably work if there was a wastgate between the two but I got sick of screwing with them.
