Bellowed up pipe install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 04-15-2014, 11:41 PM Thread Starter
I know i read a post on one of the forums a while back (dont remember which one) where a guy installed the bellowed uppipes already assembled and bolted to the Y. Any one else done this before with any luck?
The reason I ask is because i bought a set off a guy that were used but supposedly in good condition, the only thing he didnt tell me was that they were so rusted theres no chance in hell the threads can be worth a damn if i take them apart. I'm sure with enough brake fluid and kroil i could get them apart, im just afraid that once I do there wont be any thread left in the collector...
2000 F350 SCSB XLT 4X4 ZF6
MBRP 4" turbo back
6637 mod
Isspro EV Pyro & Boost Gauges
PHP Phoenix- Whisper/High-Idle/Heavy Tow/80 DD/100 Perf/120 Race
ccmac is offline
post #2 of 15 (permalink) Old 04-16-2014, 04:28 AM
duck fan's Avatar
Re: Bellowed up pipe install
The bolts IH uses in the bellowed up-pipes have dimpled threads and typically will not come apart. They are easy to drop in as an assembly if you take the downpipe out. It can be a hassle to get the downpipe out but thats easier than tearing up your up-pipes.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 15 (permalink) Old 04-16-2014, 12:12 PM
Bobs 7.3
Bobs 7.3's Avatar
Mathis does it with them all together so it can be done with care.
Bobs 7.3 is offline
post #4 of 15 (permalink) Old 04-16-2014, 12:12 PM Thread Starter
Ok thanks, I guess i should have done some more research before buying used. My down pipes only been on there a year so shouldnt give much issue.
MBRP 4" turbo back
6637 mod
ccmac is offline
post #5 of 15 (permalink) Old 04-16-2014, 04:09 PM
i did mine with them together but my turbo was off
02stroker32 is offline
post #6 of 15 (permalink) Old 04-16-2014, 04:15 PM
Canadian Stroker
doubledoor's Avatar
Pulled the turbo and the down pipe and no prob. DI up pipes are all one piece.
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
post #7 of 15 (permalink) Old 04-16-2014, 08:27 PM
International Coal Roller
jbwaldrop88's Avatar
Buy a new collector and cut the heads off the old bolts, IMO the uppies would be a PIA if the bolts are already tight when you drop the setup in, your gonna want that little bit of wiggle room
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
post #8 of 15 (permalink) Old 04-16-2014, 09:20 PM
So you guys are saying that if the turbo and down pipe are removed, the Y and up-pipes can be bolted together on the bench and lowered in place from the top of the engine bay?
2001 Lariat, F250, 7.3, 6-speed, 3:73, Ford AIS, MBRP 4" turbo back, ATS ported housing, 205° t-stat, Infinity DX w/DP Tuner 80hp tow, coolant filter, EGT & Boost gauge. 18X9 -12 Fuel Hostage with Michelin 285/65/18 stock suspension.
aclass is offline
post #9 of 15 (permalink) Old 04-16-2014, 09:29 PM
duck fan's Avatar
Absolutely. That should get you all of the room you need.
duck fan is offline
post #10 of 15 (permalink) Old 04-17-2014, 02:08 PM
Bobs 7.3
Bobs 7.3's Avatar
Yep they will drop down together. Id leave them a little loose as it will aid in lighning the turbo back up then once the turbo is installed and the clamp tight then tighten the bolts up from under the truck with a bunch of extensions and possiably a swivel.
Bobs 7.3 is offline
