Need a new exhaust tip, help, ideas? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 04-15-2014, 12:00 PM Thread Starter
Goneracin's Avatar
Send a message via AIM to Goneracin
I replaced my rotted out exhaust last year, I went with the same size system, but upgraded to stainless MBRP 5 inch. I have been soaking and heating and trying for a year to get the exhaust tip off the old pipe. Now Ive given up.
I could just get the same MBRP tip, 5 inch to 6 inch, or I could go with something else. I would like to have a 5 inch tip, I dont like the look of the tip being bigger than the exhaust. Anyone have another company to go through? Ideas? Thoughts?
2001 F-250 7.3L auto
Suspension stuff, engine stuff, reliability stuff...
Some other stuff I'm forgetting...
Goneracin is offline
post #2 of 21 (permalink) Old 04-15-2014, 12:24 PM
juvenile9's Avatar
Re: Need a new exhaust tip, help, ideas?
I'm doing a dump exhaust on mine right now. I ordered my tip off ebay for $38 shipped to the house. I haven't recieved it yet, so I can't comment on the quality. It was a stainless 5" to 6" tip, 12" long. I didn't like my pipe sticking out behind the year tire, so I removed the tailpipe section and just adding the the tip so it points towards the ground.
99.5 F-350 4x4, 6637 Air Intake, Stage 1 Single Shots, 5 Inch Exhaust, Wicked Wheel, 4" Lift, EBPV Delete, Gauges, Tru-Cool Tranny Cooler, TS 6 Position Chip with Gearhead Custom Tunes, International Bellowed Pipes, and Built Auto Tranny
juvenile9 is offline
post #3 of 21 (permalink) Old 04-15-2014, 12:32 PM Thread Starter
Goneracin's Avatar
The main problem with mine is that without a tip, the pipe is about a 1/4 inch too short. Meaning that since it is a 45 degree exit, the back edge of the pipe is just behind the bottom pinch weld on the bed. When you hit a certain RPM (right around 70 mph) it resonates off the bed and is extreeeeeemmmmly annoying. Therefore, I need something.
I found some 5 inch stainless tips from silverline for about $40, any good? or should I still spend the money on an MBRP?
post #4 of 21 (permalink) Old 04-15-2014, 12:43 PM
juvenile9's Avatar
Riff Raff has a bunch of tips on there site. The Diamond Eye tips are like thirty some dollars. I can't see spending $70 or more on an exhaust tip, but that's just me.
post #5 of 21 (permalink) Old 04-15-2014, 01:41 PM Thread Starter
Goneracin's Avatar
I dont know why I didnt think to check them, Ive been buying a lot from them recently. And yes, I agree, $70 for a tip is a lot, especially when I have a perfectly good one that I paid around that for sitting in my garage. Damn rust!
post #6 of 21 (permalink) Old 04-15-2014, 02:04 PM
CbMac87's Avatar
Did you try using an air chisel from the inside of the tip against the edge of the exhaust pipe, when i swapped my exhaust tip from my cummins exhaust to my current exhaust i heated the tail pipe up after soaking it in pb blaster and used an air chisel to push em apart other than that ive run the diamond eye tips and theyre pretty good and mine was only $33
2007 F350 King Ranch Crew Cab SRW
-4" diamond eye exhaust
-2.5" leveling Kit
-Autometer NV Gauges Boost,Pyro,Tranny Temp,Fuel Pressure
-Blacked out windows
-325/75/R20 Toyo ATs
-HIDS both fog lights and headlights
CbMac87 is offline
post #7 of 21 (permalink) Old 04-15-2014, 02:25 PM Thread Starter
Goneracin's Avatar
Yeah, Im looking at the diamond eye tips right now. I was beating it with a 5 lb sledge and still no movement. Well, the vice moved, not the tip Now its at the point where it has started to damage the tip a little, which meant it will just irritate me. Of course, as soon as I order a new one it will slide right off
post #8 of 21 (permalink) Old 04-15-2014, 02:38 PM
CbMac87's Avatar
of course it will just slide right off after you get a new one haha. ive been running my stainless steel diamond eye tip for 4 years now and it still looks new
-2.5" leveling Kit
CbMac87 is offline
post #9 of 21 (permalink) Old 04-15-2014, 02:54 PM Thread Starter
Goneracin's Avatar
Thats good to hear, thats the kind of info I need.
Did you have to trim your exhaust to make it sit right or could you slide it up the pipe as much as needed?
post #10 of 21 (permalink) Old 04-15-2014, 03:28 PM
Luddite in Charge
Mr_Andy's Avatar
I've had half success half failure with this rust seizure trick - CLR. That junk in the green spray bottle... Get it at the dollar store, and I always immerse (if possible) what I have that's frozen for about a day and then just tap it with a hammer. Like I said tho, 50% success rate. Some of the things I tried were ridiculous to even try anything less than a speedwrench but I tried it anyway
Mr_Andy is offline
