VAN TURBO INSTALATION ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 04-13-2014, 08:08 AM Thread Starter
BMF7.3's Avatar
Took a van turbo off a parts truck as well as the 4" down pipe and wanting to put it on my late 99 CC. My truck is stock and just wanting to up grade. What parts if any will I need? I was wondering about seals and clamp for turbo or anything else I might need.
BMF7.3 is offline
post #2 of 13 (permalink) Old 04-13-2014, 11:54 AM
Re: VAN TURBO INSTALATION ?
You'll need an outlet adapter....then you won't have a EBPV so you might as well delete the EBP pedestal. And it's not wastegated either, so you could clean up some of the WG solenoid wiring and tubing.
'01 F250 4x4 Crew Shorty, PM Rods, PIS 160/30's , Hydra, WW2, Monster Box, MBRP 4" 409 SSTL Exhaust, Firestone Ride-Rights, Regulated fuel return, Ford AIS.
Dan V is offline
post #3 of 13 (permalink) Old 04-13-2014, 07:03 PM
Village Idiot
southmike's Avatar
A set of dormwn up pipes might be a consideration.
bean has some sort of outlet flange you need.
southmike is offline
post #4 of 13 (permalink) Old 04-14-2014, 04:42 AM Thread Starter
BMF7.3's Avatar
I'll need an outlet adaptor even thou this set up was on a 2000 f250
BMF7.3 is offline
post #5 of 13 (permalink) Old 04-14-2014, 01:16 PM
Has it got one of these on it already?
Dan V is offline
post #6 of 13 (permalink) Old 04-14-2014, 04:12 PM
Village Idiot
southmike's Avatar
If it was on a pickup the guy prob already has that.
post #7 of 13 (permalink) Old 04-14-2014, 05:27 PM Thread Starter
BMF7.3's Avatar
I'll check and see but it was a running 7.3 that I pulled the motor and exhaust from. I'm pretty sure all the parts would be there but didn't know if I could just put the turbo and exhaust on mine with out changing the pedestal and replacing the seals
BMF7.3 is offline
post #8 of 13 (permalink) Old 04-14-2014, 06:24 PM
the stryker god
If it came off a van and has never been on a truck then you'll need that piece.
bruce51d is offline
post #9 of 13 (permalink) Old 04-14-2014, 11:55 PM
Village Idiot
southmike's Avatar
F250 your good
e250 negative
post #10 of 13 (permalink) Old 04-15-2014, 03:26 AM Thread Starter
BMF7.3's Avatar
My bad. Its a van turbo that was on a 2000 F250 with a 4" down pipe and I'm putting it on a stock late 99 psd. Idk if I needed to replace seals or gaskets.
BMF7.3 is offline
