Transmission questions... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-09-2014, 08:39 PM Thread Starter
Hey guys how's it going? Just made an account on here... I picked up a 96 F250 crew cab short bed, 2wd, e4od trans, paid 1200$ for it, its got 283000 miles on it but runs great, ive had it for 6 weeks and have already put about 5000 miles on it as well as towed alot of things,
Now for the reason of this thread, the trans is shifting really hard into gears, and if i get on it from a stop itll shift the first 2 gears fine then shift really quick into the next gear at low rpms even when im still on it... occasionally ill get in it and put it in reverse and it will stall out even if im not on the brake... so i have a filter for it and am gonna do the fluid on it (who knows if its ever been done).
I had a 93 F150 with a 5.0 and a built E4OD in it only had 9000 miles on a fresh build, upgraded sprags, alot of C6 upgraded parts, upgraded valve body, shift kit and all. My question is i can get this trans back from my buddy for 150$ with blown input shaft, will this trans work for my 7.3? What are the differences between the 2?
Thanks!
96_powerjoke is offline
post #2 of 4 (permalink) Old 04-09-2014, 08:40 PM Thread Starter
Re: Transmission questions...
And just realized this went under 99-current instead of 94-97... my bad...
post #3 of 4 (permalink) Old 04-17-2014, 12:48 PM
mech 1
check the transmition fluid is the light on the shifter on
7.3mud is offline
post #4 of 4 (permalink) Old 04-17-2014, 01:30 PM
Bobs 7.3
Bobs 7.3's Avatar
Im 99% certain a gasser trans is different then a diesel. I know the 4r100 is anyhow but Id do a fluid and filter change and flush it out threw the return line to get all the old fluid out and see what it does as the fluid can be getting wore out. Use good quality fluid as I used mobil 1 full syn and that was 10,000 miles ago in my 02 (different tranny) but that fluid still looks as good as the day I put it in and no problems even at 192,000 miles.
Bobs 7.3 is offline
