Adding leveling kit. Questions? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-08-2014, 12:16 AM Thread Starter
2000 f350 7.3l 4x4 srw. Fixin to add new x code springs along with 2.5" leveling kit to the front of truck and 4" blocks in the rear. 315/75r16 toyo mt's all the way around on stock wheels. Leveling kit came with trac bar relocating bracket. Should I purchase an adjustable trac bar, or will the bracket be enough? Could I use both bracket and adjustable trac bar together? Can I reuse my stock shocks or am I gonna need new? The most offroading this truck sees is rollin around my deer lease so, I'm hoping that rubbing will be minimal. I think I can live with some rubbing on the leaf springs. I'm expecting that at least. Is there anything I'm missing? Thanks for any input.
ford cowboy is offline
post #2 of 8 (permalink) Old 04-08-2014, 12:27 AM
duxpsd's Avatar
Re: Adding leveling kit. Questions?
My brother just did a leveling kit on his 2003 F250 with not changing anything. He is running 305 tires on his stock wheels.
2001 F250 CCLB, PHP Hydra, 6637, MBRP 4" exhaust and rear air bags
97' F250 ECLB, 7.3, Baby Swamps, Hydra w/swamps tunes, 6637, 3"dp 4" straight, Dana 60, 2.25 PMF RSK, Built Trans & Cooler, DIY efuel
duxpsd is offline
post #3 of 8 (permalink) Old 04-08-2014, 05:48 AM
jeremys's Avatar
the whole idea with leveling kit is just changing shackle mounts/spring perch, you dont have to change springs, I put 2" Leveling kit on my 01 and it raised it more like 3.5", had to put blocks in back to bring the rear back to level, I ran 35s ( I think that comes out the a 315)with no problem, I would take it to pismo and climb dunes and never had rubbing , you might need to trim plastic below front bumper,
when I say went to pismo it wasn't just pulling 5th wheel down the beach, some nights it would be making a mid-night run to the dunes after a afternoon of fun/drinking and beat the crap out of my truck still with no rubbing, that was also almost 10 years ago, Im a little more mature now, not much though
jeremys is offline
post #4 of 8 (permalink) Old 04-09-2014, 05:24 PM
You will need a adj track bar, droped Pitman arm.
maybe longer shocks and sway bar links.
email:
Website:
OBSWIZ is offline
post #5 of 8 (permalink) Old 04-11-2014, 01:17 AM Thread Starter
Who makes the best adj trac bar? Why would I need one if I have the drop bracket?
post #6 of 8 (permalink) Old 04-11-2014, 01:52 AM
Roenicke95stroker's Avatar
As long as you have the drop trac bar bracket you should be okay just see how it is when you install it. But If you go with an adj trac bar I would get one from Precious metal fab.
Roenicke95stroker is offline
post #7 of 8 (permalink) Old 04-11-2014, 04:27 PM
Best track bar....Icon.
email:
Website:
OBSWIZ is offline
post #8 of 8 (permalink) Old 04-11-2014, 09:33 PM
jeremys's Avatar
my leveling kit is from ICON, very nice, my old truck I bought a cheap 2" LK, it worked good but no way same quality as ICON
http://iconvehicledynamics.com/shop/...er-system.html
99 F250 4x4SD CC SB
stage 1 injectors
6 stage TS chip
6.0 trans cooler-#1 mod for 99 if towing
billet Torque converter
Dorman bellowed up-pipes-installing this weekend
AIH delete,snowman mod,pillar gauges-boost/egt's/trans temp,ICON leveling kit front/blocks rear,Bilstein shocks,6.0 grill,towing mirrors from 06,35" tires on 18's
jeremys is offline
