Did your turbo get louder with RR billet wheel? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 04-07-2014, 10:10 PM Thread Starter
Carolina444's Avatar
My turbo got a lot louder after riffraff billet wheel install.. It actually sounds like a boost leak in low boost in overdrive. I've looked for leaks but haven't found any. I easily can get 26-28lbs boost and egt's are ok. Anyone else seem louder? Thanks
E99 f250 2wd cclb,257k, tymar intake, stock turbo w/ riffraff billet wheel, PIS 230/100,regulated return, hbjr, pmt1, hydra w/dynoproven and powerstruck tunes, 140v Idm, 4" exhuast, isspro's, ccv, ebpv delete, jwvb w/6.0 cooler
Coming soon: BASB
Carolina444 is offline
post #2 of 25 (permalink) Old 04-07-2014, 10:15 PM
Re: Did your turbo get louder with RR billet wheel?
how much did you get the rr wheel for? im not sure if I should go with that or xdp x wheel
ChrisM426 is offline
post #3 of 25 (permalink) Old 04-07-2014, 10:45 PM
shaggy's Avatar
Just out of curiosity...why the billet wheel? Your sig says you have an E99. You should already have a "wicked wheel" from the factory? Could that have anything to do with the sound?
Unless you're like me and have a e99 production date with a late 99 motor.
E99 with 99.5 motor 7.3 (from factory) ZF6 Ext Cab/ Long Bed. 6637 mod. MBRP 4". Auto Meter Ultra Lite II Pyro/Boost. PHP Hydra. Leveled on 35" BFG A/T's.
shaggy is offline
post #4 of 25 (permalink) Old 04-07-2014, 11:00 PM
Dunmo why he did it, but the new WW2 and RR billet wheel builds more boost and spins up faster
99 F350 (99.5 motor E99 suspension)
Rebuilt tranny (with shift kit) @ 114,000
6637, Foil Delete, IC tubes Boots and clamps cleaned
kenmore is offline
post #5 of 25 (permalink) Old 04-07-2014, 11:37 PM Thread Starter
I think it was around $200 off their site
Coming soon: BASB
post #6 of 25 (permalink) Old 04-07-2014, 11:41 PM Thread Starter
The factory ww isn't a performance item.. It was only made to fix surge.. The Billet wheel woke the truck up but it's louder than I expected. Got a 7lb more boost than factory wheel
Coming soon: BASB
post #7 of 25 (permalink) Old 04-08-2014, 02:46 AM
shaggy's Avatar
Well thats good to know! I didn't think it gain alot on a e99. Sweet! next mod for girlfriends e99 then!
shaggy is offline
post #8 of 25 (permalink) Old 04-08-2014, 02:52 AM
carolina7.3's Avatar
I have a E99 mfd jan 98 an see the same results as carolina444. would recommend the RR billet wheel as great upgrade to stock turbo.
E99 F-250 Mfd Jan 98, 6637, 6fin billet comp wheel, from riffraff.com, stage I & II ebp delete, 86ed, ScanGauge II, TJM bull bar, bosch field burners, 4" downpipe 4" single stack, Hutch n Harpoon Mod, galaxy dx 44v, PHP Hyrda
E99, F350 CCLB, DRW, RR comp wheel, Superchip 1705, couple other mods
chris
carolina7.3 is offline
post #9 of 25 (permalink) Old 04-08-2014, 09:18 AM Thread Starter
Did your turbo get louder or change sound?
Coming soon: BASB
post #10 of 25 (permalink) Old 04-08-2014, 12:53 PM
Goneracin's Avatar
Send a message via AIM to Goneracin
I just did the RiffRaff wheel last weekend, yes it did get louder, and when I'm cruising up a hill at about 10 psi it does sound like a boost leak. But like you said, I'm making 30 pounds of boost at WOT and EGTs are fine so I don't think I have a leak.
That billet wheel really did wake the truck up, great driveability improvement, especially while towing.
2001 F-250 7.3L auto
Suspension stuff, engine stuff, reliability stuff...
Some other stuff I'm forgetting...
Goneracin is offline
