HELP stuck!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 04-05-2014, 11:54 PM Thread Starter
HELP stuck!!
Did this once before. Didn't have any info. Hasn't done it for a couple years. I am beside the road. My 99 F350 is spitting and studdering. The HPOP is showing 2700-2800 but my in IPR jumps from 30-40 to 60%...everything else reads normal. Ideas? Fuel filter is new as of 2 days ago and changed oil yesterday.
99 F350 (99.5 motor E99 suspension)
Rebuilt tranny (with shift kit) @ 114,000
6637, Foil Delete, IC tubes Boots and clamps cleaned
kenmore is offline
post #2 of 17 (permalink) Old 04-06-2014, 12:04 AM
Luddite in Charge
Mr_Andy's Avatar
Re: HELP stuck!!
How filthy was the old filter? If it was a mess, you might have knocked a bunch of goo loose and into one or more injectors
Mr_Andy is offline
post #3 of 17 (permalink) Old 04-06-2014, 12:18 AM Thread Starter
Re: HELP stuck!!
It was really pretty clean. Didn't have any clogs or discoloration. I even drained the bowl. Drove 240 miles earlier and waited 4 Hrs. Now I'm driving the same 240 back. 120 miles into the trip back and now this.
kenmore is offline
post #4 of 17 (permalink) Old 04-06-2014, 12:23 AM Thread Starter
Re: HELP stuck!!
Fired it back up after sitting about 10 minutes and its running rough but not trying to die. At WOT the IPR is 40-45% and HPOP is still holding 2800ish. Tranny temp good, oil level good, I'll pop the hood to check for a fuel leak from the bowl. But I suspect it will be fine. No puddles when I just stopped.
kenmore is offline
post #5 of 17 (permalink) Old 04-06-2014, 02:34 AM Thread Starter
Re: HELP stuck!!
Last 120 miles...injectors sounded a tiny bit louder than usual. But ran fine, no hiccups. I'm at a loss. Another side note. When I was despise the road at rough idle. I floored it and there was a smokey haze coming out. But after the 10-15 rest period it ran a little rough and then smoothed back out. I'm completely lost.
kenmore is offline
post #6 of 17 (permalink) Old 04-06-2014, 10:48 AM
JJozwiak's Avatar
Re: HELP stuck!!
I would Con-cur with MR. Andy I think you got something stuck in an injector, you might have worked it loose!
JJozwiak is offline
post #7 of 17 (permalink) Old 04-06-2014, 01:29 PM
POWER Junkie
PSD POWER007's Avatar
Re: HELP stuck!!
With the truck running, unplug one bank of injectors at the valve cover and compare how each side runs. That would help to see if it is injector related. If there is a difference, pull that valve cover and unplug one injector at a time.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #8 of 17 (permalink) Old 04-17-2014, 12:52 PM
mech 1
Re: HELP stuck!!
how old is your oil if it is breaking down it will foam and ack like a bunch of bad injectors
7.3mud is offline
post #9 of 17 (permalink) Old 04-17-2014, 05:33 PM
OBS Stroker
Nodge's Avatar
Re: HELP stuck!!
Codes?
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #10 of 17 (permalink) Old 04-17-2014, 11:28 PM
mech 1
Re: HELP stuck!!
Ice sensor will cause these issues some times the connection is loose or oily
7.3mud is offline
