7.3 transmission cooler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-05-2014, 11:39 PM Thread Starter
Early99
I have a aftermarket transmission cooler. I see 150-180 degree this winter. I bought a 6.0 31 row cooler the other day. My question is, can you have the transmission temp to cool for hauling trailers? I pull trailers 80% of the time. Maybe 9,000 lb trailer.
Diverhardhat is offline
post #2 of 5 (permalink) Old 04-06-2014, 12:54 AM
POWER Junkie
PSD POWER007's Avatar
Re: 7.3 transmission cooler
No. No matter what you do, you will run about 80-90 degrees above ambient with proper cooling.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #3 of 5 (permalink) Old 04-06-2014, 01:46 PM
Caption This
444-4D's Avatar
It depends on what the outside temp is. In real cold temps it is possible for the fluid temp to be too low. You can remedy that by installing a thermostat on the cooler lines.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #4 of 5 (permalink) Old 04-07-2014, 12:35 AM
Hansel's Avatar
I've been running an 6.0L cooler and during the winter I would not see any temp over 100*, so I installed a Derale bypass valve that is helping bring the tranny temp up but the highest temp I've seen is 170* but it hasn't gotten really hot yet, so I'm wondering how it's going too handle the summer temps and hauling my 8,000lb+ camper. The nice thing is that I have the fittings so if I need too bypass the valve I can and run the cooler without the valve.
2001 7.3L CCSRW 4X4 Lariat
Airaid intake
Stock for now
Hansel is offline
post #5 of 5 (permalink) Old 04-07-2014, 02:28 AM
300,000 and counting's Avatar
I see about 125* towing with my 31 row when it's below 40*; above 40* outside it can get from 150-180* that's towing on country roads with 7-8 tons on the 28' trailer. Where the real help comes in is if the tranny gets hot the cooler cools it down quick.
2001 7.3 PSD, Swamps 200/30 injectors, 38r turbo, HPx, FRx, bellowed up-pipes, non-ebpv ped, Gearhead tuned TS 6 pos chip, AFE big boost intake, 4" downpipe; 5" exhaust, BTS valve body, 31 row tranny cooler, autometer gauges, 05-07 front end, centurion rear bumper, 327,000 miles FOR SALE
2009 6.4 PSD, 71mm LP, studded, delete, H$S Mini Max
300,000 and counting is offline
