Pyro probe - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-05-2014, 01:31 PM Thread Starter
Pyro probe
Will it make a difference if I install the egt probe in the turbo exhaust housing or should it be down where header meets up pipe, only reason I ask is because I took out ebpv and where the shaft came the housing I pressed out bushings, tapped and installed 1/2 npt plugs where shaft was. So I already got threaded ports to install probe in an easy location
E99 F 250 4x4 Lariat
Buckeye Wes is offline
post #2 of 8 (permalink) Old 04-05-2014, 01:35 PM
Re: Pyro probe
Pre-turbo, easiest spot is drivers side exhaust manifold. Where the header meets the up pipe. Post turbo will be much hotter.
2002 F-250 7.3 4x4. Intake, Exhaust, all the "Guzzle" mods, 300k on the truck, 50K Running on straight WVO.
MTNSTROKE is offline
post #3 of 8 (permalink) Old 04-05-2014, 01:35 PM
carolina7.3's Avatar
Re: Pyro probe
Driver side header is recommended
E99 F-250 Mfd Jan 98, 6637, 6fin billet comp wheel, from riffraff.com, stage I & II ebp delete, 86ed, ScanGauge II, TJM bull bar, bosch field burners, 4" downpipe 4" single stack, Hutch n Harpoon Mod, galaxy dx 44v, PHP Hyrda
E99, F350 CCLB, DRW, RR comp wheel, Superchip 1705, couple other mods
chris
carolina7.3 is offline
post #4 of 8 (permalink) Old 04-05-2014, 03:24 PM
'05 Excursion
Term3's Avatar
Re: Pyro probe
Much cooler you mean. :)
Sent from AutoGuide.com App
Term3 is offline
post #5 of 8 (permalink) Old 04-05-2014, 06:01 PM
Re: Pyro probe
, yup. Thanks for fixing it for me.
post #6 of 8 (permalink) Old 04-06-2014, 04:21 PM
Carolina444's Avatar
Re: Pyro probe
Mine is in the driver manifold.. IMO it's the best and easiest spot to install it
E99 f250 2wd cclb,257k, tymar intake, stock turbo w/ riffraff billet wheel, PIS 230/100,regulated return, hbjr, pmt1, hydra w/dynoproven and powerstruck tunes, 140v Idm, 4" exhuast, isspro's, ccv, ebpv delete, jwvb w/6.0 cooler
Coming soon: BASB
Carolina444 is offline
post #7 of 8 (permalink) Old 04-06-2014, 04:29 PM
Banned
brettboat's Avatar
Re: Pyro probe
I got a band clamp from glow shift... But it was improperly tapped by them (fine threads and course threads don't mix). So I have a funky set up with my probe involving a hose clamp, safety wire and DOW 736 Red RTV.... Figure if safety wire and red RTV can handle the heat a turbine puts out, it can handle the exhaust on my powerstroke. But I installed it on the passenger side manifold right where it meets the uppipe... There's a nice flat spot there
brettboat is offline
post #8 of 8 (permalink) Old 04-07-2014, 12:34 AM
International Coal Roller
jbwaldrop88's Avatar
Re: Pyro probe
I wouldn't put it in the housing, the closer you can get to the cylinders the more accurate your reading is gonna be, it's really not for turbo temperature, it's for cylinder temperature so you dont burn a hole in a piston, etc. Mines in the driver side manifold.
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
