Ccv - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-02-2014, 11:57 PM Thread Starter
Ccv
What are people using to plug hole on cold air intake after flipping dog house around?
E99 F 250 4x4 Lariat
Buckeye Wes is offline
post #2 of 7 (permalink) Old 04-03-2014, 12:39 AM
Re: Ccv
Replace it with a piece of 4" OD exhaust tubing about 4-6 inches long.
2002 F-250 7.3 4x4. Intake, Exhaust, all the "Guzzle" mods, 300k on the truck, 50K Running on straight WVO.
MTNSTROKE is offline
post #3 of 7 (permalink) Old 04-03-2014, 01:41 AM
whistle tits
ghohouston's Avatar
Re: Ccv
I siliconed a dime or nickel (can't remember which, but I think a dime) to the bottom of the hole, and put more silicone on the inside of the intake pipe, so it sat level with the rest of the pipe, and of course let it dry.
ghohouston is offline
post #4 of 7 (permalink) Old 04-03-2014, 06:26 AM
Terminator Nation
Re: Ccv
This works the best since there is no restriction that the CCV adaptor has with its venturi.
I made a bracket that mounted the exhaust pipe section to the same mount as the factory CCV adaptor, its a 50* angle.
old man dave is offline
post #5 of 7 (permalink) Old 04-03-2014, 09:52 AM Thread Starter
Re: Ccv
I like remounting the pipe
Thanks
post #6 of 7 (permalink) Old 04-03-2014, 12:39 PM
carolina7.3's Avatar
Re: Ccv
ive seen some people use a 3" ID PVC coupler but I did the 4" OD exhaust pipe myself
E99 F-250 Mfd Jan 98, 6637, 6fin billet comp wheel, from riffraff.com, stage I & II ebp delete, 86ed, ScanGauge II, TJM bull bar, bosch field burners, 4" downpipe 4" single stack, Hutch n Harpoon Mod, galaxy dx 44v, PHP Hyrda
E99, F350 CCLB, DRW, RR comp wheel, Superchip 1705, couple other mods
chris
carolina7.3 is offline
post #7 of 7 (permalink) Old 04-03-2014, 03:36 PM
OBS Stroker
Nodge's Avatar
Re: Ccv
I removed the nipple and cut a piece of plastic oil jug to fit. Jb weld in place.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
