What clutch? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-31-2014, 12:14 AM Thread Starter
Hell Raiser
What clutch?
I sold my SB clutch that I hadn't installed yet cuz I had a buddy in need for a clutch bad. What clutch will hold up to my current setup? It'll be my dd and I'll pull/race it rarely. I want it to hold the power and a few boosted launches but don't need a stiff clutch as I sit in traffic on my commute home. Not loyal to SB or valair just looking for the best setup. Do I need a dual disk or single? Steel or ceramic? Thanks for the help
99.5 F350 SCLB ZF6 4x4, 6637 and foil delete for now. S468, 400/400, t4 uppipes, swamp tunes, arp studs, smith bros pushrods, comp 910s with shims, 4" MBRP DP to 5" to 6" stack, diesel site fuel system, SB clutch ready to be installed
Timmy is offline
post #2 of 9 (permalink) Old 04-02-2014, 02:55 AM Thread Starter
Hell Raiser
Re: What clutch?
Bump
Timmy is offline
post #3 of 9 (permalink) Old 04-04-2014, 11:18 PM
International Coal Roller
jbwaldrop88's Avatar
Re: What clutch?
I honestly would say another SB, I think ceramics are too grabby for a dd, and unless your racing duals are too
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
post #4 of 9 (permalink) Old 04-05-2014, 01:50 AM
Re: What clutch?
I love my SB street dual disk but I don't know if it would hold up very long to 400/400's if it was me I would go with a SB Iron giant
96 F350 PIS 300/200 BTS HPOP studs/pushrods/910s S468 Coolingmist water
97 F250 FF 160/100 17*HPOP RR Airdog studs/pushrods/910s Banks Intercooler GTP38/S475 twins Dana 60
01 F250 PIS 300/200 BTS HPOP GT42 built bottom end
09 F-350 Studs egr/dpf delete powerstroke67 dp RCD converter Mini Max
Dynoproven Tuning
Death to all single disk clutches
pwrstrk01 is offline
post #5 of 9 (permalink) Old 04-05-2014, 04:36 PM
Re: What clutch?
I run a sb. Single disc. One side is organic the other is ceramic. I forget which one it actually is but it's not to stiff for a dd. U can slip it some but grabs good.
01 f-250 7.3. XL lariat interior w/pw, pl, and tilt. 203* t-stat, dp-80 econo, FASS filtration and pump, SB clutch,4" turbo back, muffler delete, fuel bowl delete, ebpv delete diy regulated return, 6637
spothead1979 is offline
post #6 of 9 (permalink) Old 04-06-2014, 03:57 AM
Re: What clutch?
Your going to need a dd clutch for that kind of power. Just phone south bend and get them to recommend a clutch.
swaan is offline
post #7 of 9 (permalink) Old 04-06-2014, 04:42 PM
Re: What clutch?
How s your tuning? If it throws a lot of torque early (and I know with 400's it will to some extent) you might need a dual regardless
post #8 of 9 (permalink) Old 04-06-2014, 06:08 PM Thread Starter
Hell Raiser
Re: What clutch?
I've not installed the parts yet. There's no way a stock clutch will hold this setup. The clutch is the last thing I need before I tear it all apart. I've got a hydra chip with php tunes. Will and gearhead and swamp tunes also
It's a 300k stock bottom end so the last thing I want is gobs of torque down low and throw a rod. I know to never bog the engine down for fear of bent/broken rods. At what rpm can I "get on it" and not have to worry about rod failure?
Timmy is offline
post #9 of 9 (permalink) Old 04-07-2014, 12:25 AM
Re: What clutch?
I don't ever get on mine below 1500, but I have pmrs so it's different for me. It's hard to say really, your rods may hold 500hp for another 300k, or it might not, it's impossible to tell if there are any microscopic cracks in the rods or not.
