need wiring harness - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-30-2014, 05:15 PM Thread Starter
need wiring harness
i have a 2001 7.3 6 speed manual with electronic 4x4. some stuff happened and the wiring harness that hooks to the main engine harness then to the fuel pump it also goes to the transfer case and the reverse lights. as far as i know ford no longer produces this harness and im have a lot of trouble finding it anywhere. any info about where i can get one of these harnesses would be greatly appreciated. thanks
speedkills is offline
post #2 of 9 (permalink) Old 03-30-2014, 06:20 PM
whistle tits
ghohouston's Avatar
Re: need wiring harness
Ford should still sell the harness, but if not, best bet is to find one from a junkyard or part out. What makes you think the harness its self is bad?
ghohouston is offline
post #3 of 9 (permalink) Old 03-30-2014, 07:03 PM Thread Starter
i went to a ford distribution center and they could not get it for me. the harness i have was physically destroyed we couldnt even salvage it to try and make it work.
post #4 of 9 (permalink) Old 03-30-2014, 07:05 PM
OBSpstroke97's Avatar
How did it get destroyed?
1997 F-250, D60, 8in lift/38s, OUO ladder bars, BTS, Spearco 6.0 IC, SRP 1.1, Irate 468 turbo, Dyno proven tunes, P.I.S 300/200s, ARPs/910s/Smith bros push rods, A1000/sump.
[email protected] on 38s
OBSpstroke97 is offline
post #5 of 9 (permalink) Old 03-30-2014, 07:08 PM Thread Starter
front drive shaft broke and ripped a lot of wiring out including that harness is what i was told. my buddy had my truck while i was in Afghanistan so i wasnt there.
post #6 of 9 (permalink) Old 03-30-2014, 07:13 PM
Just curious because its very rare. It sounds like you shouldn't let your buddy use your truck ever again. Good luck with the harness. If I see any ill let u know.
post #7 of 9 (permalink) Old 03-31-2014, 12:53 AM
Luddite in Charge
Mr_Andy's Avatar
1st, HOOAH bro..
2nd, what is not working now? If it's just a neutral safety issue (won't start) that's easily bypassed and the schematics/wire colors are probably available on this site...
If it's as boogered as you said then I guess you're having issues with everything from lights to fuel pumps not working, and that should be a broken nose for that 'friend' of yours. Especially under the circumstances concerning what you were off doing.
There's a wealth of knowledge on this site and everyone is more than willing to contribute help/facts/suggestions/ideas, so let it rip with what wasn't as it was and you'll get idea after idea how to fix it.
Mr_Andy is offline
post #8 of 9 (permalink) Old 03-31-2014, 01:18 AM Thread Starter
hooah sappers.
the truck runs right now it has an automatic 2wd harness in it right now i believe. the reverse lights and the 4x4 are the only two things not working as of now. im just tired of not having 4x4 so im looking for the harness one last time before i convert it to a manual shift 4x4. if someone knows how to make one of the harnesses or what im open to sugestions but finding a harness at a junk yard is what i keep running into and i havnt found one yet.
post #9 of 9 (permalink) Old 03-31-2014, 02:17 AM Thread Starter
or if anyone knows of a good salvage yard that specializes on ford trucks that might work i could always call and ask.
