30 psi ICP while cranking..no oil out of ICP hole. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 03-30-2014, 02:47 PM Thread Starter
No start situation, while cranking the injector control pressure is reading at 30 psi. Pulled the ICP and cranked. Oil barely comes out of the hole. Thinking bad IPR or possibly HPOP?
What would be a good aftermarket option for 160/100 injectors in an OBS?
1997 CC SB, auto->ZF-5, 160/80, 4", gearhead
Sold - 2000 Ex 4wd 7.3, 6" lift, 35s, afe stage 2 intake, banks intercooler, DI up-pipes, 38r w/ Non-EBV pedestal and hi flow adapter, ISSPRO EV2 gauges, FASS, fuel bowl delete, and DIY RR, modded 17* hpop, GPR LED, CCV
a5t1 is offline
post #2 of 21 (permalink) Old 03-30-2014, 03:40 PM
whistle tits
ghohouston's Avatar
Re: 30 psi ICP while cranking..no oil out of ICP hole.
Is the tin nut on the ipr tight? Checked wiring to the ipr?
ghohouston is offline
post #3 of 21 (permalink) Old 03-30-2014, 03:53 PM
IHPowerstroke7.3's Avatar
Does your oil gauge on cluster show oil pressure when cranking? That would show whether or not you have some low pressure oil pressure.
IHPowerstroke7.3 is offline
post #4 of 21 (permalink) Old 03-30-2014, 03:59 PM
SledDogg's Avatar
Onlu 30 psi pretty much rules out a IPR. Ipr rarely fail. Get a Honeybadger Jr. Hpop from Dyno Proven - NEW NAME! . Will support 250/200% sticks.
But first scan it for stored codes.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #5 of 21 (permalink) Old 03-30-2014, 04:46 PM Thread Starter
Yes, oil gauge is moving.
I installed the injectors about 4-5 months ago (from rosewood) with new orings. Maybe a hold down came loose or a ring failed? Really not sure.
Tin is tight on IPR. Again, this truck has 370k on it so that makes me think maybe HPOP or IPR? Why would the IPR be ruled out?
a5t1 is offline
post #6 of 21 (permalink) Old 03-30-2014, 04:46 PM
Village Idiot
southmike's Avatar
Send out some pm or emails to terminator, dieselsite and dynoproven.
they should each be able to help narrow your search quickly.
also each has a good pump option availible, anyone of which will be an improvement.
Over a stock pump...damaged or not.
Your no start could be unrelated...ie a bad connection on the shift lever, bad ipr etc.
Battery level is also a big issue not to be overlooked.
southmike is offline
post #7 of 21 (permalink) Old 03-30-2014, 05:45 PM
POWER Junkie
PSD POWER007's Avatar
Same thing happened to me...turned out to be injector o-rings.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #8 of 21 (permalink) Old 03-31-2014, 01:20 AM
SledDogg's Avatar
You guys are misding his key piece of info.....no oil coming out if icp hole and 30a psi is hpop. All 8to orings could leak, 2 sticks could be dumping oil....it would still start. It ran then didn't. Hpop is thrash ....I've been through this twice, always the pump.
SledDogg is offline
post #9 of 21 (permalink) Old 03-31-2014, 03:07 AM
Sled dog, not necessarily.
Op, verify you have voltage at the IPR. No voltage to the IPR, it will be full open, ie full bypass. Also, if a piece of debris is in the IPR and it's stuck open, you won't build pressure either.
If all that checks out, then check injector O rings and HPOP.
TerminatorEngineering is offline
post #10 of 21 (permalink) Old 03-31-2014, 04:49 AM
POWER Junkie
I had ONE injector with a bad o-ring. Mine would only build 30-40 psi and would never start. Mine barely would push oil out of the ICP hole. Sent the Arenaline back for testing, it was fine, had them send a freshly rebuilt IPR back with the pump. Still no change. Pulled the valve covers off and the very front injector on the drivers side was puking oil. Decided to upgrade injectors, got them installed and pressure built up right away and she fired right up.
Just my experience with a very similar story to the OP's
