Leveling or Lift Kit? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-29-2014, 10:51 PM Thread Starter
PSN Newbie
protsman3's Avatar
On my 7.3 I have stock height with 33in tires and no rubbing, I recently bought 17in rims with 35in tires. Would a leveling kit fit that? or should I go with a 4in lift?
2001 Ford F-250 7.3 Powerstroke
Black, 175k
K&N Intake, Heavy Duty Transmission, 4in Straight Pipe Exhaust 5in Tip, Edge Evolution Programmer, DVD/CD Head Unit
protsman3 is offline
post #2 of 13 (permalink) Old 03-30-2014, 12:09 PM
dadada's Avatar
Re: Leveling or Lift Kit?
4" lift
2001 F-250 4X4 SCSB 7.3 Auto X Codes w/ 2" Hanger/Shackle Drop Kit-38R w/Turbomaster,AFE, T500, Regulated Return, 6.0 Tranny Cooler, JWVB, 4"Exhaust, Hydra w/ Gearhead, PHP, and Powerstruck tunes, Powerstruck 180/100's Live Tuned by Powerstruck and then some!
dadada is offline
post #3 of 13 (permalink) Old 03-30-2014, 12:54 PM
Luddite in Charge
Mr_Andy's Avatar
4" lift will run you $2k+ and give you the feel of a Cadillac. 3.5" levelling kit will run you $600 and give you all the room you need for 37's and the ride will be like that of a 3/4 or 1 ton truck. Oh wait, wasn't that what you put it on in the first place? People will get very defensive and touchy over why a lift is better because of the ride characteristics blah blah blah but to all those people I say "then you should have lifted a Mercedes"
Mr_Andy is offline
post #4 of 13 (permalink) Old 03-30-2014, 02:27 PM
00stroke97
97-BIG RED's Avatar
I'm running 325/65/18s with a leveling kit and 4inch rear blocks but I do have some rubbing with driver side
00 7.3 powerstroke 180,000k:
05-06 front end swap,recon cab lights, zf6, SB 1939 -CB single disk clutch, 4inch turbo back, ts 6 php tunes, afe stg1, isspro boost and egt gauges, leveled with 4inch blocks, 325-65-18s coopers, tgc dual steering stabilizer, rock gaurd,
old truck;
97 obs zf5
ts 6, tymar intake 4inch turbo back, 4inch lift
97-BIG RED is offline
post #5 of 13 (permalink) Old 03-30-2014, 08:34 PM
AnyThingCanHappen's Avatar
Have a 2'' Leveling kit (well extra spring in the front and block in the back) and have Nitto 295/70R18 which are about 34.5 tall and 11.77 wide. That is on an excursion and have no rubbing any bigger and it would rub at full turn
2002 Ford Excursion 7.3L
2000 Ford Ranger 5.0L efi swapped
2003 Ford Mustang Cobra
Excursion mods:
4'' exhaust, superchips cortex, wicked wheel, banks big head, K&N cold air, 2'' life/leveling kit, 2008 King ranch wheels with 35's, 05 Headlights, 05 chrome grill
AnyThingCanHappen is offline
post #6 of 13 (permalink) Old 03-31-2014, 12:29 AM
FuturePharmD's Avatar
I think a leveling kit and 350 blocks in the rear should do just fine. My tires are 34.5 and I've got plenty of room to spare.
2002 F250 ccsb Lariat 4x4
6637 intake
4" MBRP
Stage 1's by Full Force Diesel
Honey badger Jr hpop and Brute 66
Bellowed up-pipes and blank pedestal
No Limit Tuning by Jonathan (Dyno Proven)
Rough country level and shocks
305/70r16 Toyo AT2 on Dc2
Autometer factory match (pyro,boost,trans)
FuturePharmD is offline
post #7 of 13 (permalink) Old 03-31-2014, 01:24 AM
dadada's Avatar
The tires in your signature are not 34.5 inches unless your running something different.
dadada is offline
post #8 of 13 (permalink) Old 04-01-2014, 05:32 AM
Monster in the making
BigTruckBuck's Avatar
39.5x 13.5 stock height. You could skip the lift and go for cut outs.
Early 99 4x4 Ext Cab Short Bed. Cosmetic Mods, Turbo Back Twin 6in Stacks. Bushwackers Cut-outs Fender Flares. BFG Baja Projects.
BigTruckBuck is offline
post #9 of 13 (permalink) Old 04-01-2014, 05:56 AM Thread Starter
PSN Newbie
protsman3's Avatar
I'm thinking of going with the 4 inch lift....
Black, 175k
post #10 of 13 (permalink) Old 04-05-2014, 01:16 AM
Haven't updated my signature in a while. Running toyo open country at2 in 315/75r16 now.
6637 intake
4" MBRP
