Couple of problems after single shot install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-25-2014, 03:44 AM Thread Starter
Four weeks ago I installed FF single shot 160cc injectors along with a myriad of other repairs to my trucks. Since that time I am now getting a P1316 which I never had with the stock injectors. I pulled the valve covers and went through all of the connections including ohm testing everything and its all good. The SES light flashes sporadically when I am driving and never stays on. I also don't really notice any engine issues when it flashes so I am stumped as to what cause may be.
Also, when I had my chip re-burned it wouldn't make good contact with my PCM anymore. I re-tinned the pins and thought all appeared to be well but 50% of the time when I go to start my truck I will get a properly operating WTS light but my fuel pump and glow plugs won't turn on. If I cycle the key a few times the chip with then "turn on". I notice once the truck is running that it will sporadically stumble like the chip is turning off and on. I am stumped by this one too. All in all it's been pretty disappointing as I got rid of poorly running injectors only to have my truck run worse.
Any help would be greatly appreciated!
Blderman is offline
post #2 of 9 (permalink) Old 03-28-2014, 02:58 PM Thread Starter
Re: Couple of problems after single shot install
Bump.....anyone?
Blderman is offline
post #3 of 9 (permalink) Old 03-28-2014, 05:16 PM
POWER Junkie
PSD POWER007's Avatar
Who tuned the chip? Maybe contact them...
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #4 of 9 (permalink) Old 03-28-2014, 05:35 PM
duck fan's Avatar
P1316 is usually the UVCH coming loose but I assume you checked that. Often, especially when doing injectors, the plug outside the valve cover works loose. Double check both connections. Either of them making intermittent contact can cause your P1316
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #5 of 9 (permalink) Old 03-28-2014, 07:17 PM Thread Starter
Peter, yes, I have new harness and connectors. Tore everything apart this past weekend just to double check and it was all good. Never had a single SES light before the injectors. Now it flashes on/off at random whether the chip is in or not.
TW is revising the tuning for me but I still can't figure out how the chip can work one cycle of the ignition and not the next. And when driving I can feel it turn off/on but the truck doesn't stall. Very stumped by both problems, starting to regret going with single shots.
Blderman is offline
post #6 of 9 (permalink) Old 03-28-2014, 07:48 PM
fueled by Colecovision
golfer's Avatar
Garage
see this thread
Wits End with Random SES Light - PowerStrokeNation : Ford Powerstroke Diesel Forum
golfer is offline
post #7 of 9 (permalink) Old 03-28-2014, 10:08 PM Thread Starter
I used all OEM harness/connectors so I don't believe that to be the problem. It would appear that I may have injector issues. How do you isolate which injector it is if a buzz test passes and there are no other symptoms than the P1316?
Blderman is offline
post #8 of 9 (permalink) Old 03-29-2014, 02:44 AM
Village Idiot
southmike's Avatar
A breakout box.
a homemade box that plugs in to the harness and has 8 switches...
you simply turn them on and off as needed.
there was a guy that made them or rented it...no idea who. It was .
might try searching injector breakout box.
The thread had pics and directions.
southmike is offline
post #9 of 9 (permalink) Old 03-29-2014, 03:51 PM Thread Starter
Originally Posted by southmike View Post
A breakout box.
Thanks, I looked into that and it is certainly a great idea. Unfortunately I just sank $3,000 into my truck and don't have a dime more to spend. I was really hoping the last round of cash was going to be the end of my problems........
Blderman is offline
