DieselSite HPOP filter adapter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-25-2014, 01:49 AM Thread Starter
recordbreaker5's Avatar
I have installed this piece to my front cover on my current build up. It says it requires some modding to the fuel lines since it moves the fuel bowl up higher. Has anyone added this filter plate? If so, how did you go about fitting your lines to the new height required. I'm not sure if there is some bending or adding some additional fuel line with AN fittings or something like that.
Dieselsite HPOP Reservoir Filter Adapter for 1994-2003 7.3L
recordbreaker5 is offline
post #2 of 4 (permalink) Old 03-25-2014, 10:49 PM
International Coal Roller
jbwaldrop88's Avatar
Re: DieselSite HPOP filter adapter
What model engine do you have, if it's a 99.5 and later you already have this.
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
post #3 of 4 (permalink) Old 03-26-2014, 04:18 AM Thread Starter
I got a donor engine from an early 99 for my 2001. I just reused the donor front cover because it was on the stand and built the motor before pulling mine out of the truck. A buddy of mine had an early 99 and never installed on his truck, traded some fishing stuff for it, probably would have never spent $230 on this piece otherwise.
post #4 of 4 (permalink) Old 03-29-2014, 03:36 AM
Village Idiot
southmike's Avatar
Just bend the lines a bit..
southmike is offline
