block fill on a daily driver - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-24-2014, 08:59 PM Thread Starter
powerstrokin44's Avatar
I was wondering if anybody is running a filled block on their DD and tows with it? I was going to fill everything up to 2" below deck height. I threw a rod and dont want to have to pull my motor again because of a cracked block. Is it worth doing while its out or am I going to have to worry about it overheating? I already bought a girdle to help a little and im pushing close to 600 hp. And also if I do it should I just use hard-blok and how much of it do I need to buy? Any info will help. Thanks
2000 F-250 Stroker, Cale's tunes, modded H2E, Full Force 250/100, Built tranny from John Richmond, Precision converter, Manley rods, Mahle pistons, clevite bearings, girdle, sbi valves, a1000, Comp springs, Smith bros pushrods, billet plenums, DI RR.
powerstrokin44 is offline
post #2 of 7 (permalink) Old 03-24-2014, 09:11 PM
flocksmonster garage's Avatar
Re: block fill on a daily driver
Not trying to hi jack this but what does it mean to fill a block?
TS chip
Autometer gauges
E99 spider and intercooler
Mag-Hytec trans pan
6.0 trans cooler
Transgo tugger shift kit
AFE stage 2 intake
3 inch down pipe to 4 inch to 5 inch duals
35x13.5-20 atz radial
and some other miscellaneous dumb high school kid mods
flocksmonster garage is offline
post #3 of 7 (permalink) Old 03-24-2014, 11:50 PM Thread Starter
You fill the water jackets with a cement like material to help keep it from cracking or flexing where its thin between the water jackets and cylinder walls. Just basically helps keep the structural integrity of the block.
post #4 of 7 (permalink) Old 03-25-2014, 01:48 AM
Won't filling it completely block water flow though?
TS chip
Autometer gauges
Mag-Hytec trans pan
6.0 trans cooler
AFE stage 2 intake
post #5 of 7 (permalink) Old 03-25-2014, 03:10 AM
m j
m j's Avatar
I am filling my new motor
I bought some moroso filler
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
post #6 of 7 (permalink) Old 03-25-2014, 05:05 AM
Worth it? Probably.
I know of a few people that have filled DD builds.
Here is a good read on block filling:
http://www.###############.com/forum...ead.php?t=7731
Replace the # signs with f o r d d i e s e l p o w e r . c o m (and remove the spaces)
FYI: I'm not trying to advertise, just a really great read that will help OP.
1997 F350 CCLB Dually
Mahle Ceramic Coated Pistons, Billet Crower C-Rods, Chromoly P-Rods, Beehive Springs, Fire Ring HeadGaskets, ARP H-Studs, Girdle, Mellings LPOP, Twin Termmies, 300/200 Injectors, Dual SD Fuel Pumps, Billet Plenums, 6.0 mishimoto intercooler, Compound Turbos, John Wood Tranny, 4921 Transmission Cooler.
Pwnm30rdi3 is offline
post #7 of 7 (permalink) Old 03-25-2014, 09:55 AM
OBSpstroke97's Avatar
I just recently started researching this. So can it be done by the weekend mechanic ? Or does it need to be machined after?
1997 F-250, D60, 8in lift/38s, OUO ladder bars, BTS, Spearco 6.0 IC, SRP 1.1, Irate 468 turbo, Dyno proven tunes, P.I.S 300/200s, ARPs/910s/Smith bros push rods, A1000/sump.
[email protected] on 38s
OBSpstroke97 is offline
