aluminum an fittings - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-22-2014, 12:41 PM Thread Starter
I'm doing a lot of work to my truck currently and one of them is redoing my whole fuel system. I didn't know if anyone has dealt with using aluminum an fittings on the heads. Pretty much I want 6an to 1/8 at a 45. I would rather steel but I'm having trouble finding steel ones. Any help would be appreciated. Thanks
01 f-250 7.3. XL lariat interior w/pw, pl, and tilt. 203* t-stat, dp-80 econo, FASS filtration and pump, SB clutch,4" turbo back, muffler delete, fuel bowl delete, ebpv delete diy regulated return, 6637
spothead1979 is offline
post #2 of 7 (permalink) Old 03-22-2014, 03:02 PM
'05 Excursion
Term3's Avatar
Re: aluminum an fittings
I like steel better also which is why I use SwagLock fittings and stainless steel hard tubing.
Sent from AutoGuide.com App
Term3 is offline
post #3 of 7 (permalink) Old 03-22-2014, 06:39 PM
m j
m j's Avatar
steel fittings will be called JIC. any hydraulic shop will have them.
-06JIC to 1/8npt 45deg
parker 6-2 VTX
Eaton C5355X6X2
3/8 MPT Steel 45Deg Elbow | Fastenal
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
post #4 of 7 (permalink) Old 03-22-2014, 10:55 PM Thread Starter
Thank you
post #5 of 7 (permalink) Old 03-23-2014, 12:16 PM
I do a lot with swagelok at work. Top notch fittings in my opinion. I would love to replace everything with 316ss. They also offer a bellows style high pressure line that can handle high temps as well as high pressures.
Ja_cain is offline
post #6 of 7 (permalink) Old 03-23-2014, 03:37 PM
'05 Excursion
Term3's Avatar
I just put in a oil bypass filter setup with their PTFE line SS hoses in a buds truck. I think the 3,000 PSI pressure rated hoses should just barely handle it.
Only thing is its hard to find metric threaded SwagLoc in North America as I've had to order the ones I need since work doesn't get them in.
Term3 is offline
post #7 of 7 (permalink) Old 03-24-2014, 12:00 PM
m j
m j's Avatar
I used stainless tubing and JIC flare to do my fuel system and HPO lines.
what did you find with metric thread in the oil system?
m j is offline
