Longevity mods - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 50 (permalink) Old 03-20-2014, 03:54 AM Thread Starter
crawlake's Avatar
Longevity mods
Hey guys,
I just bought a 2000 cclb dually with 47000 miles on it. Looking for suggestions on any mods I can do to make this truck last as long as possible, maybe coolant filter, etc. Any suggestions would be greatly appreciated, thanks.
crawlake is offline
post #2 of 50 (permalink) Old 03-20-2014, 12:33 PM
Chachi
7.3PowerStroke602's Avatar
Re: Longevity mods
if you want it to last, you mise well not even touch anything, just keep up with the maintenance, you've got a jewel of a motor with little mileage so you should be golden. as long as you take care of it it will take care of you
2003 F350 7.3 Turbo Diesel
Rancho 9000 Shocks
4 inch exhaust into Soflo diesel 7 inch Mitre Stack
AFE Stage 2 Cold Air Intake
Glowshift Gauges-Fuel Pressure,Boost,Exhaust Temp. Aeroforce Interceptor Gauge on the Column
Swamps TS 6 Position Chip
Leveled Height with 35 Nitto Mud Grapplers
Swamps Diesel Boost Fooler
7.3PowerStroke602 is offline
post #3 of 50 (permalink) Old 03-20-2014, 12:57 PM
Re: Longevity mods
The list I am going to give will be highly debatable. I will give reasons for them... you don't really need any of them. Fluid and filter changes will trump any of these mods. Fresh fluids and fuel will keep this little beast running for a long time. These mods are just things to do if you want a little more insurance...keep in mind. Anytime you mess with your truck, you always have a chance of causing an issue. Classic case of, if its not broken don't fix it, kinda thing. That being said, here ya go.
6637 intake and 4" exhaust (free flowing air in and out)
Hutch and Harpoon (help keep air out of injectors, let's u top off your tank)
FRx (helps keep air out of injectors)
HPx (evens out oil pressure to the heads)
6.0 trans cooler (keeps trans cooler)
Coolant filter (keeps coolant cleaner)
CCV mod (keeps oil out of intake system)
Clean your EBP tube...little maintenance thing that gets over looked. I am guilty of this.
99 F350 (99.5 motor E99 suspension)
Rebuilt tranny (with shift kit) @ 114,000
6637, Foil Delete, IC tubes Boots and clamps cleaned
kenmore is offline
post #4 of 50 (permalink) Old 03-20-2014, 01:30 PM
Old Yeller, REBORN
kilapapipa's Avatar
Re: Longevity mods
The words "longevity" and "mods" don't really go together. Longevity means maintenance and mods means playing with fire in my opinion. These trucks come from the factory as a set of common denominators and as soon as you change that with mods, you are taking chances.
Maybe adding things like a coolant filter would fit both.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #5 of 50 (permalink) Old 03-20-2014, 02:01 PM
Caption This
444-4D's Avatar
Re: Longevity mods
If your truck was made before February 2000, you need to upgrade the transmission cooler. There is also a Ford air cleaner upgrade that you should do.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #6 of 50 (permalink) Old 03-20-2014, 04:11 PM Thread Starter
crawlake's Avatar
Re: Longevity mods
Is there any cases where doing the Donaldson B085011 filter and an exhaust has affected longevity of an engine? 444-4D, you mentioned an air cleaner upgrade, what has to be upgraded on it? Thanks again for the replies
2001 f350 ccsb, AFE stage 2, gauges, tuning by gearhead, locally built tranny.
2000 f350 cclb dually. Bone stock
crawlake is offline
post #7 of 50 (permalink) Old 03-20-2014, 04:51 PM
Old Yeller, REBORN
kilapapipa's Avatar
Re: Longevity mods
Can't think of any on the exhaust but if you don't get that filter sealed up good, you can dust your engine.
post #8 of 50 (permalink) Old 03-20-2014, 05:18 PM
Bobs 7.3
Bobs 7.3's Avatar
Re: Longevity mods
Toss the leaky prone air box and throw a 6637 filter with adapter on it. Very easy to get a good seal and eliminates up the restrictive factory box. Id also put a good free flow exhaust on it as the filter and exhaust together will gain ya a bit of mpg more and cooler egts. Besides that keep good quality fluids in it and regular maint on everything and it will be long lived.
Bobs 7.3 is offline
post #9 of 50 (permalink) Old 03-20-2014, 05:40 PM
the stryker god
Re: Longevity mods
ais intake, 4" exhaust, hutch mod and frx, done
bruce51d is offline
post #10 of 50 (permalink) Old 03-20-2014, 06:55 PM Thread Starter
crawlake's Avatar
Re: Longevity mods
Thanks for the info guys. I think I'll do an exhaust and intake, and a coolant filter. How about a swamps modded IDM? Would that help the stock injectors last? Or is it more of a performance mod?
crawlake is offline
