Can Edge Insight CTS replace analog gauges? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-18-2014, 06:53 PM Thread Starter
My chip is on its way and I'm looking to buy gauges and was thinking about the Edge Insight CTS. Any thoughts?
I was told that it reads through the PCM or something, and it uses your trucks instruments to give you the reading. Would that be accurate?
Also that it wasn't able to read fuel pres and that usually seems be the 4th gauge people opt to get.
So I guess I would have to run a separate gauge if I wanted to get that. How important is this gauge?
Finally, I was told that it never came with an EGT sensor. That's the most important if your not doing much towing, eight?
zack179 is offline
post #2 of 4 (permalink) Old 03-18-2014, 07:05 PM
Re: Can Edge Insight CTS replace analog gauges?
You can buy the egt probe separate I believe. The insight is going to read whatever the computer sensors read since its reading thru your obd-II port. I had one in conjunction with my gauges and it was pretty close to what my gauges read also. I liked the ability to read codes and troubleshoot.
OBS73 is offline
post #3 of 4 (permalink) Old 03-18-2014, 07:42 PM
the stryker god
nothin will leave you stranded on the side of the road faster than 0 fuel pressure. they are nice but for me I like my 4 gauges and ae or the torque app for everythin else
bruce51d is offline
post #4 of 4 (permalink) Old 03-18-2014, 10:39 PM Thread Starter
So I can get away with using the torque app with a egt and pres guage?
zack179 is offline
