Is 600+ HP obtainable with 238cc/100 injectors? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 03-18-2014, 03:17 PM Thread Starter
What is the highest HP I can get out of my 238cc/100 hybrid injectors? I currently have those injectors, a modded H2E, irate competition fuel system, head studded, standard forged connecting rods, hypermax push rods, hypermax valve springs, intake, 4 inch turbo back, hydra chip with gearhead automotive tuning. Will a stage 2 stealth HPOP get me there with new tunes?
7.3powerstroke88 is offline
post #2 of 17 (permalink) Old 03-18-2014, 03:34 PM
OBS Stroker
Nodge's Avatar
Re: Is 600+ HP obtainable with 238cc/100 injectors?
Probably 500-525ish.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #3 of 17 (permalink) Old 03-18-2014, 04:49 PM
the stryker god
nope, but the 250/200's i have for sale will
bruce51d is offline
post #4 of 17 (permalink) Old 03-18-2014, 05:57 PM
there have been trucks that are out there that have made 600ish with 250/100s. the right turbo and oil set up with an aggressive tuner you can make the power. but 90% of people with them injectors are in the 500ish hp range like said below. i personally know 1 truck with the said HP i mentioned but it cracked a few pistons after a year or 2
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #5 of 17 (permalink) Old 03-18-2014, 08:09 PM
300,000 and counting's Avatar
These will barely get you there, but if my goal was 600hp I would be running 250/200
2001 7.3 PSD, Swamps 200/30 injectors, 38r turbo, HPx, FRx, bellowed up-pipes, non-ebpv ped, Gearhead tuned TS 6 pos chip, AFE big boost intake, 4" downpipe; 5" exhaust, BTS valve body, 31 row tranny cooler, autometer gauges, 05-07 front end, centurion rear bumper, 327,000 miles FOR SALE
2009 6.4 PSD, 71mm LP, studded, delete, H$S Mini Max
300,000 and counting is offline
post #6 of 17 (permalink) Old 03-18-2014, 08:53 PM Thread Starter
Thanks, I talked to Nate at Unlimited Diesel and he said he can modify the 238cc/100 into 300cc/200.
post #7 of 17 (permalink) Old 03-18-2014, 09:00 PM
assuming you have all the right mods/air/drivetrain/valve train then thoughs injectors should put you where you want to be
post #8 of 17 (permalink) Old 03-18-2014, 09:29 PM
If you dont mind me asking how much does that cost
post #9 of 17 (permalink) Old 03-18-2014, 09:54 PM Thread Starter
$1200 to modify them. I only have 10,000 miles on them. 300cc/100 hybrids go for $2500 so the modified route is a cheaper option.
post #10 of 17 (permalink) Old 03-18-2014, 09:56 PM Thread Starter
300cc/200* sorry ^
