Dangit! One Wheel Peel..... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 63 (permalink) Old 11-16-2007, 12:51 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
So as many of you know I took the lift off a few weeks ago. When I did this I swapped my 4.56 geared complete axles for a complete set with 3.73s as I would now be running 35s. Anywho, the rear axle I ended up with has a freakin open diff. NO LS.
I can fry my right side 35 even in my tow file. It will go straight to the rev limiter if I dont watch it. (bounced the tach a few times recently)
What is an inexpensive, but effective easy to swap in solution to my problem?
Truck runs awesome on the highway (love my tranny Slim hooked me up with) and will own anything just about in this area. (not a brag, just no hot trucks over here. lol)
PTSUPERD is offline
post #2 of 63 (permalink) Old 11-16-2007, 12:56 PM
NEVRNF's Avatar
Re: Dangit! One Wheel Peel.....
Are you sure the clutches are not just worn? I would pull the cover and see what is in there.
Tony
02 Excursion CR conversion with a few go fast parts
The truck
should have built
FOR SALE
NEVRNF is offline
post #3 of 63 (permalink) Old 11-16-2007, 01:43 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
Not sure Tony. I am ignorant when it comes to axles etc. I think I'll get it checked out.
PTSUPERD is offline
post #4 of 63 (permalink) Old 11-16-2007, 01:54 PM
OEM Moderator
Tom S's Avatar
Seems like Dalsf250 had an Auburn in the for sale section recently.
Tom
Tom S is offline
post #5 of 63 (permalink) Old 11-16-2007, 02:03 PM
rebelchevy02's Avatar
Cheap solution : Weld the spider gears together
Best solutioin: Detroit locker.
I have a detroit locker in mine, and everytime you even slightly touch the go pedal, they are locked. You can feel it in every turn when going from coast to on the throttle.
I dont have much faith in the factory limited slips, they always seem to wear out, and very quickly at that. I have had luck with EATON limited slips, they are fully rebuildable, and adjustable. I wouldnt waste the time putting in a factory LS, they just arent worth the trouble for me. Ive had my detroit in for a while, and just absolutely love its traction ability!
DRW and tow fast parts.......
rebelchevy02 is offline
post #6 of 63 (permalink) Old 11-16-2007, 02:03 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I need to do something too... sucks, anytime the roads are wet I may as well put it in 4wd...
Joe
CSIPSD is offline
post #7 of 63 (permalink) Old 11-16-2007, 02:04 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
What do you know about one wheel peels, you don't race.
Anywho it supposed to be a LS, jack up the rear and turn one side and see what happens.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #8 of 63 (permalink) Old 11-16-2007, 02:04 PM
CSIPSD's Avatar
I could get a factory LS on the account (if I could) how hard would it be to install? Would you have to set the lash and crap up?
Joe
CSIPSD is offline
post #9 of 63 (permalink) Old 11-16-2007, 02:29 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
Hardy -har -har
With my old rear axle (sitting in your shop) never had this problem. With that one, both sides grabbed prolly 70&#37; of the time. Think I got the short end of the stick. lol
PTSUPERD is offline
post #10 of 63 (permalink) Old 11-16-2007, 02:31 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Easiest solution is to just change the axle fluid and don't add any modifier. Worked for my peg leg differential. It doesn't hop around turns, but it acts like a locked differential when i spin 'em, it's not one goes, then the other catches up, they BOTH unhook and go.
Stock
PowerstrokeJunkie is offline
