drive pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-16-2007, 01:01 AM Thread Starter
mattrac's Avatar
Question drive pressure
any one know what the drive pressure of a stock turbo should be around @30psi boost?
2001 F250
mattrac is offline
post #2 of 10 (permalink) Old 11-16-2007, 01:01 AM
Re: drive pressure
With a .84 housing? Probably 70psi
gregrob is offline
post #3 of 10 (permalink) Old 11-16-2007, 01:17 AM Thread Starter
mattrac's Avatar
Re: drive pressure
im running 40psi drive at 30psi boost?
2001 F250
mattrac is offline
post #4 of 10 (permalink) Old 11-16-2007, 01:18 AM
Re: drive pressure
Then your sensor isn't working properly
gregrob is offline
post #5 of 10 (permalink) Old 11-16-2007, 01:50 AM
OEM Moderator
Tom S's Avatar
Re: drive pressure
How are you measuring it?
Tom
Tom S is offline
post #6 of 10 (permalink) Old 11-16-2007, 02:21 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: drive pressure
On a gauge, you will get 55-60psi of drive pressure with a stock .84 housing. Depends on the wastegate, if you have it wired down tight it will give more back pressure, but if you are running more fuel at a higher temperature, you will likely get the same results with a few less pounds of force.
Stock
PowerstrokeJunkie is offline
post #7 of 10 (permalink) Old 11-16-2007, 02:35 AM
Re: drive pressure
A little off subject kinda..... What is the max ideal back pressure you should run with this motor? I mean any turbo setup where would the "sweat spot" be?
mustang_gt_350 is offline
post #8 of 10 (permalink) Old 11-16-2007, 02:41 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: drive pressure
1 to 1 is what you want... but can you get it? Its hard... The Stocker is to about 13#... the 38r is to about 25#'s and the TN drop in is to about 30#'s... I have not tested the TN BB yet...
The 38r with a 1.15 housing is 1 to 1 to about 32#'s
Joe
CSIPSD is offline
post #9 of 10 (permalink) Old 11-16-2007, 02:56 AM
Bigfoot is an OBS
cowboy_dan's Avatar
Re: drive pressure
Drive pressure Vs. boost pressure will depend on several things.
1. Steady state vs. accelerating: Accelerating drive pressure will be significantly more than steady state.
2. Exhaust housing: Smaller will have more back pressure until the WG opens.
3. Compressor: WW or similar will have lower drive pressure simply because it doesn't waste power trying to be quiet.
4. Exhaust: Stock will be more restrictive. Any back pressure in the post-turbo exhaust will increase the pre-turbo exhaust back pressure.
That's all I can think of for now
Go ARMY!
cowboy_dan is offline
post #10 of 10 (permalink) Old 11-16-2007, 02:57 AM
Re: drive pressure
Thanks for the reply. thats what i was looking for. I knew the lower the better but i didnt know what turbo's ran what so i had somthing to compare with.
