Crank rear seal plate removal? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 11-14-2007, 09:10 PM Thread Starter
AllYourBaseAreBelongToUs
imelmo's Avatar
I've about got the block completely stripped down to be sleeved for the Fordota but EVERY SINGLE FRIGGIN' SCREW but one on the rear plate is stripping. They're 8mm and I've been trying to use a 6 point socket and they just round off. Tried using the Craftsman screw extractor and it won't fit completely over the head.
Anybody got any suggestions?
Nestep is to break out the grinder and grind the heads off and hope I can get the leftover screws out with vice grips.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #2 of 11 (permalink) Old 11-14-2007, 10:01 PM
DILLIGAFF
Send a message via AIM to Redfish
Re: Crank rear seal plate removal?
Just get a bunch of cheap 8mm sockets at harbor freight and weld them bastards to the bolts. Then back them out with the impact gun.... that is if your patient welder, and a good one.
2006 F-250 CC King Ranch, Harley Headlights w/ 55w HIDs
ARP studs, MBRP 4" exhaust and AM Colbalts By:
, AFE stg. 2 Pro Guard 7 from XDP, SCT from innovative!
14.09 @ 94 1.85 60'
Redfish is offline
post #3 of 11 (permalink) Old 11-14-2007, 10:17 PM
<<<<< Next Generation
boggerr's Avatar
Try a 5/16 six point. When you put it on tap it a few times with a hammer then try to back it out.
N.E. Terminator Tech
2000 F350 Lariat CC 4x4 LWB Auto
DP-Tuner F5, Terminator HPOP, QSSB, ITP's fuel system, BTS trans.
boggerr is offline
post #4 of 11 (permalink) Old 11-14-2007, 11:28 PM
OEM Moderator
Tom S's Avatar
Weld a nut on the bolt head is my suggestion.
Tom
Tom S is offline
post #5 of 11 (permalink) Old 11-15-2007, 12:02 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Yes, a 5/16 or 1/4 nut, where you can weld the top of the head to the inside of the nut for more strength.
Stock
PowerstrokeJunkie is offline
post #6 of 11 (permalink) Old 11-15-2007, 12:55 AM
South Atlanta white trash
Doodie's Avatar
That's crazy, striping? When I pulled my plate off the old motor it was covered in oil. Good luck Danny
Garmon's Diesel Performance
SOLD...
01' F250 CC 7.3
16.5:1, Mahle's .0050 with harden forged, 37 deg. valve job, Comp 910's, 4130 pushrods, Mac/K&N
H-11 studs, HT turbo, DP tuned, Bean's injectors/plentums, DI's fuel system
Built trans with Red Altos/PI triple disc.
2010 CC 6.4, 6" lift, 20's & 35's
Doodie is offline
post #7 of 11 (permalink) Old 11-15-2007, 12:58 AM
You need to gain some weight, and cut your hair
"let's go mud ridin" LFMAO
gregrob is offline
post #8 of 11 (permalink) Old 11-15-2007, 01:08 AM
Recovering basher!!!!!
Try an EZ-Out. Drill the appropriate size hole, insert the EZ-Out and turn the EZ-Out counterclockwise with a wrench.
You may also try heating it up a little.
DeadStroke is offline
post #9 of 11 (permalink) Old 11-15-2007, 01:13 AM
The Stig
BFD99's Avatar
Send a message via AIM to BFD99 Send a message via MSN to BFD99
i would weld on a bolt or socket before EZ-out seeing as you can always try the EZ out after you weld on a bolt.
2006 Ram 5.9L 2wd Gogodiesel, Garmon's Diesel
2010 Dually 6.4L, Gogodiesel, KEM Tuned
BFD99 is offline
post #10 of 11 (permalink) Old 11-15-2007, 01:20 AM
Plays with Motors
Machinist's Avatar
90% of the time you can take a brass drift and smack the head of the bolt, relieving the stress on the threads and it will turn right out. If that doesn't do it, heat the bolt up till it's almost red-hot, then squirt some pb blaster on it, let it cool and then it should come out.
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
