Whats tunes? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 11-13-2007, 01:07 PM Thread Starter
Smile Whats tunes?
I am about to send my chip to Tony Wildman for get it burned for my 99' and need some help with the tunes to install. My setup is in my sig, I figured I would ask you guys instead of a trial and error mailing the chip back and forth. Thanks!
Apowerstroker is offline
post #2 of 24 (permalink) Old 11-13-2007, 02:05 PM
godofdew11's Avatar
Send a message via AIM to godofdew11
Re: Whats tunes?
i don't see anything about gauges in your sig, without at least a pyrometer i would be EXTREMELY conservative with what tunes you get if any.. i know certain PCM codes will get the EGTs way up there even stock.
after that i dont know anything about twildman im a DP:nutswinger:
-Don
'03 F-350 SC LB, 4x4 7.3, loaded, 3.5" DP to 4" Ex, tymar intake, 38r, strobes and LEDs galore. windshield mount 3 gaude pod,Gearhead toonz,BTS VB, 2.5" leveing kit. Toyo 315s. Last of the 7.3's
godofdew11 is offline
post #3 of 24 (permalink) Old 11-13-2007, 08:08 PM Thread Starter
Re: Whats tunes?
Im good on keepin an eye on things, just curious what tunes to start with....anyone else?
post #4 of 24 (permalink) Old 11-13-2007, 08:40 PM
Re: Whats tunes?
How do u keep an eye on things without a pyro gauge?????
Diezel Dawg is offline
post #5 of 24 (permalink) Old 11-13-2007, 10:20 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Whats tunes?
Here are a few pic's of keeping an eye on it...
But hey, if you melt it down you can just build it stronger... for about 8k...
Joe
CSIPSD is offline
post #6 of 24 (permalink) Old 11-13-2007, 10:54 PM
Re: Whats tunes?
Damn Joe, and u kept an eye on things WITH your gauges! I wish i had the know how to watch things WITHOUT!!! would have saved me some money!
post #7 of 24 (permalink) Old 11-13-2007, 11:23 PM
CSIPSD's Avatar
Re: Whats tunes?
Ok OK... so not TQing down an injector caused the last one but...
Joe
CSIPSD is offline
post #8 of 24 (permalink) Old 11-13-2007, 11:30 PM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: Whats tunes?
A very expensive mistake, and a bigger leason. Bet you never do that again.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #9 of 24 (permalink) Old 11-13-2007, 11:33 PM
All done now
Arisley's Avatar
Re: Whats tunes?
Get guages first. Only reason I have no tunes yet.
Arisley is offline
post #10 of 24 (permalink) Old 11-13-2007, 11:35 PM
skylinedan's Avatar
This remind me of something I did a few years ago. I had a 2000 chevy 1500 5.3 I took a pair of heads reworked the ports and some other stuff, put them on, forgot that the headbolt bores are dead and hydroliced the block craking it in a few spots, never leaked, but I though it was done stick it with a fork. Was,nt long after that I totaled it down from the shop, proble a good thing I allwas say.
Dan
